[GRASS-user] partial vector copy to smaller territory
Frank David
frank.david at geophom.fr
Wed Oct 31 06:53:49 PDT 2018
Hi Stefan,
Thank you. I did not know. That's great.
Cheers,
Frank
Le 31/10/2018 à 13:53, Stefan Blumentrath a écrit :
> Hei Frank,
> Did you try the “spatial” option in v.in.ogr (or the r-flag) (if your
> data is in a shape-file to start with):
> https://grass.osgeo.org/grass74/manuals/v.in.ogr.html?
> And is v.clip slower than v.overlay (that could be used as well)?
> Cheers
> Stefan
> *From:*grass-user <grass-user-bounces at lists.osgeo.org> *On Behalf Of
> *Frank David
> *Sent:* onsdag 31. oktober 2018 13:14
> *To:* Veronica Andreo <veroandreo at gmail.com>
> *Cc:* grass-user <grass-user at lists.osgeo.org>
> *Subject:* Re: [GRASS-user] partial vector copy to smaller territory
> Hello Vero,
> Thanks for your reply. It took almost one hour to extract my area (I
> guess because of topology). I do the same with Qgis from a shape in
> less than 10 minutes (but with several operations)... it's may be a
> bad idea to have a so heavy vector map in Grass...
> Cheers,
> Frank
> Le 31/10/2018 à 11:26, Veronica Andreo a écrit :
> Check v.extract or v.clip
> Cheers,
> Vero
> El mié., 31 oct. 2018 7:20, Frank David <frank.david at geophom.fr
> <mailto:frank.david at geophom.fr>> escribió:
> Hello,
> What is the best and fast way to make a copy of a part of
> vector map
> (national) to get a smaller territory ? (partial copy).
> Thank you for your advice !
> Frank
> grass-user mailing list
> grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/grass-user
-------------- section suivante --------------
Une pièce jointe HTML a été nettoyée...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20181031/fc3c387e/attachment-0001.html>
