[GRASS-user] Help with r.landscape.evol
Isaac Ullah
iullah at sdsu.edu
Mon Sep 17 12:16:45 PDT 2018
Hello all, sorry I didn't see this earlier. I will investigate the bug and
suggestion by Helmut and make any changes. I will try to add some examples
to the help file as well.
~Isaac
On Wed, Sep 12, 2018 at 12:00 PM <grass-user-request at lists.osgeo.org> wrote:
> Send grass-user mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
> https://lists.osgeo.org/mailman/listinfo/grass-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> grass-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of grass-user digest..."
> Today's Topics:
> 1. Re: Help with r.landscape.evol (Helmut Kudrnovsky)
> 2. Re: Help with r.landscape.evol (Helmut Kudrnovsky)
> ---------- Forwarded message ----------
> From: Helmut Kudrnovsky <hellik at web.de>
> To: grass-user at lists.osgeo.org
> Cc:
> Bcc:
> Date: Wed, 12 Sep 2018 10:23:07 -0700 (MST)
> Subject: Re: [GRASS-user] Help with r.landscape.evol
> Nicholas Uwadia wrote
> > Thanks makus for your reply, i have added more details as required and
> > also
> > the error experienced.
> > operating system :windows 10
> > GRASS GIS: 7.4
> tested here with OSGeo4W-winGRASS 7.4.1
> r.landscape.evol --verbose elev=elevation at PERMANENT initbdrk=bedrock at user1
> smoothing=no prefx=levol_ outdem=elevation outsoil=soildepth number=1
> statsout=D:\temp\testadd\test.txt
> STARTING SIMULATION
> Beginning iteration sequence. This may take some time.
> Process is not finished until you see the message: 'Done with everything'
> _____________________________________________________________
> Total number of iterations to be run is 1
> Iteration = 1
> Iteration 1 -- step 1: calculating slope
> Iteration 1 -- step 2: calculating accumulated flow depths
> Calculating runoff excess rates (uplsope accumulated cells scaled to
> "flowcontrib" map
> Iteration 1 -- step 3: calculating sediment transport rates (units variable
> depending upon process)
> Iteration 1 -- step 4: calculating divergence/difference of sediment
> transport for each process and the actual amount of erosion or deposition
> in
> vertical meters/cell/year
> Running soft-knee smoothing filter...
> No additional modal smoothing was requested...
> ERROR: Unable to load rules file
> <c:\users\hkmyr\appdata\local\temp\grass7-hkmyr-8260\tmp3ykzyr>
> Traceback (most recent call last):
> File "C:\Users\hkmyr\AppData\Roaming\GRASS7\addons/scripts
> /r.landscape.evol.py", line 681, in <module>
> main(x, (x + 1), prefx, statsout, region1['nsres'],
> masterlist);
> /r.landscape.evol.py", line 509, in main
> grass.run_command('r.colors', quiet = "True", map =
> netchange, rules = nccolors.name)
> File "C:\OSGEO4~1\apps\grass\grass-7.4.1\etc\python\grass\
> script\core.py", line 421, in run_command
> return handle_errors(returncode, returncode, args,
> kwargs)
> script\core.py", line 332, in handle_errors
> returncode=returncode)
> grass.exceptions.CalledModuleError: Module run None
> ['r.colors', '--q', 'rules=c:\\users\\hkmyr\\appdata\\local\
> \temp\\grass7-hkmyr-8260\\tmp3ykzyr', 'map=levol_ED_rate']
> ended with error
> Process ended with non-zero return code 1. See errors in the
> (error) output.
> confirmed
> it seems there is an issue with r.colors reading a temporary color rules
> file.
> best regards
> Helmut
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
> Cc:
> Bcc:
> Date: Wed, 12 Sep 2018 11:20:53 -0700 (MST)
> > kwargs)
> > ended with error
> > (error) output.
> it seems
> https://trac.osgeo.org/grass/browser/grass-addons/grass7/raster/r.landscape.evol/r.landscape.evol.py#L509
> 509 grass.run_command('r.colors', quiet = "True", map = netchange,
> rules
> = nccolors.name)
> https://trac.osgeo.org/grass/browser/grass-addons/grass7/raster/r.landscape.evol/r.landscape.evol.py#L522
> 522 grass.run_command('r.colors', quiet = "True", map = new_soil,
> rules
> = sdcolors.name)
> that the rules fille for these 2 r.colors command aren't correctly defined
> in the script.
> locally changing these 2 lines e.g. to
> grass.run_command('r.colors', quiet = "True", map = netchange, color =
> 'viridis')
> grass.run_command('r.colors', quiet = "True", map = new_soil, color =
> 'viridis')
> then the addons script finishes:
> r.landscape.evol elev=elevation at PERMANENT initbdrk=bedrock at user1
> statsout=D:\wd\test\log.txt
> STARTING SIMULATION
> Iteration = 1
> "flowcontrib" map
> in
> Iteration 1 -- step 5: calculating terrain evolution and new soil depths
> Iteration 1 -- step 6: writing stats to output file
> Outputing stats to textfile: D:\wd\test\log.txt
> Cleaning up temporary maps...
> Done with Iteration 1
> Iterations complete!
> (Wed Sep 12 20:16:14 2018) Command finished (43 sec)
> best regards
> Helmut
Isaac I. Ullah, PhD
Assistant Professor of Anthropology
Anthropology Undergraduate Adviser
San Diego State University
Fall Advising Office Hours: *W 1-2:30pm AL 480*
Fall Lab Hours: *T-Th 2-3pm HT 66*
Modelling feedbacks between human and natural processes in the land system
<https://www.earth-syst-dynam.net/9/895/2018/>
Derek T. Robinson, Alan Di Vittorio, Peter Alexander, Almut Arneth, C.
Michael Barton, Daniel G. Brown, Albert Kettner, Carsten Lemmen, Brian C.
O'Neill, Marco Janssen, Thomas A. M. Pugh, Sam S. Rabin, Mark Rounsevell,
James P. Syvitski, Isaac *Ullah*, and Peter H. Verburg
Earth Syst. Dynam., 9, 895-914, https://doi.org/10.5194/esd-9-895-2018, 2018
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180917/8d0d1714/attachment.html>
