[GRASS-user] Interpolating rainfall data across area from points
Rich Shepard
rshepard at appl-ecosys.com
Mon Sep 24 12:25:03 PDT 2018
On Mon, 24 Sep 2018, Micha Silver wrote:
> The guidelines that I follow include:
> * Rainfall interpolation (of any kind) should be done only for long time
> periods = at least a full season. since you are looking at 13 years of
> data then this requirement is fulfilled.
> * The rules of thumb for "how many points" for kriging interpolation
> usually says > 30. So again you are fine.
> * The GRASS modules offer only ordinary kriging AFAIK, which might be
> appropriate in this case. But if you want to use Kriging with External
> Drift with the elevation as the secondary "trend" variable, I think
> you'll need to go with with R. Having said that, I think that "the
> jury is still out" on whether elevation improves the interpolation or
> not.
Micha,
Thanks for the insights. I think that OK would be adequate for now because
the climate is changing and this is a long-term project that will be
monitored and and adjusted as necessary,
Regards,
Rich
