[GRASS-user] EPSG 32633 and spatial resolution for hourly LST product from Copernicus
Nikos Alexandris
nik at nikosalexandris.net
Tue Sep 25 07:51:16 PDT 2018
* Veronica Andreo <veroandreo at gmail.com> [2018-09-25 08:24:44 -0300]:
>AFAIU, plate carree (lat long grid, no meters) is deprecated, and you
>should use latlong instead. I had a similar issue with modis ocean color
>products.
>Do you at least get the same number of row and columns that is described by
>gdalinfo when you import?
No, it is 512^2 (see below) against
g.regio -p
rows: 3584
cols: 8064
Markus' hint, not *directly* on the netCDF file, rather on one of the
layers:
gdalinfo NETCDF:"g2_BIOPAR_LST_201606220100_GLOBE_GEO_V1.2.nc":LST
Driver: netCDF/Network Common Data Format
Files: g2_BIOPAR_LST_201606220100_GLOBE_GEO_V1.2.nc
Size is 8064, 3584
Coordinate System is:
GEOGCS["unknown",
DATUM["unknown",
SPHEROID["Spheroid",6378137,298.2572326660156]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]]]
Origin = (-180.022321429103613,80.022321429103613)
Pixel Size = (0.044642858207226,-0.044642858207226)
Metadata:
crs#grid_mapping_name=latitude_longitude
crs#inverse_flattening=298.2572326660156
crs#longitude_of_prime_meridian=0
crs#semi_major_axis=6378137
lat#axis=Y
lat#long_name=latitude
lat#standard_name=latitude
lat#units=degrees_north
lon#axis=X
lon#long_name=longitude
lon#standard_name=longitude
lon#units=degrees_east
LST#add_offset=273.15
LST#ancillary_variables=Q_FLAGS, ERRORBAR_LST, TIME_DELTA, PERCENT_PROC_PIXELS
LST#cell_methods=area:mean where land
LST#coverage_content_type=physicalMeasurement
LST#grid_mapping=crs
LST#long_name=Land Surface Temperature
LST#scale_factor=0.01
LST#standard_name=surface_temperature
LST#units=Kelvin
LST#valid_range={-7000,8000}
LST#_FillValue=-8000
NC_GLOBAL#algorithm_version=GOES13-LST_v3.40, MSG3-LST_v7.14.0, HIMAWARI8-LST_v3.50, DataFusion_v5.2
NC_GLOBAL#archive_facility=IPMA
NC_GLOBAL#comment=Land Surface Temperature (LST) is the radiative skin temperature over land. LST plays an important role in the physics of land surface as it is involved in the processes of energy and water exc
hange with the atmosphere. LST is useful for the scientific community, namely for those dealing with meteorological and climate models. Accurate values of LST are also of special interest in a wide range of areas
related to land surface processes, including meteorology, hydrology, agrometeorology, climatology and environmental studies.
NC_GLOBAL#contacts=Principal investigator (Researcher): isabel.trigo at ipma.pt; Instituto Português do Mar e da Atmosfera (IPMA); Rua C ao Aeroporto; Lisbon; 1749-077; Portugal (PT); IPMA website; http://www.ipma.
pt
Originator (IPMA GIO-Global Land Help Desk): sandra.coelho at ipma.pt; Instituto Português do Mar e da Atmosfera (IPMA); Rua C ao Aeroporto; Lisbon; 1749-077; Portugal (PT); IPMA website; http://www.ipma.pt
Point of contact (GIO-Global Land Help Desk): helpdesk at vgt.vito.be; Flemish Institute for Technological Research (VITO); Boeretang 200; Mol; 2400; Belgium (BE); VITO website; http://land.copernicus.eu/global/
Owner: ENTR-COPERNICUS-ASSETS at ec.europa.eu; European Commission Directorate-General for Enterprise and Industry (EC-DGEI); Avenue d'Auderghem 45; Brussels; 1049; Belgium (BE); EC-DGEI website; http://ec.europa.eu/
enterprise/
Custodian (Responsible): copernicuslandproducts at jrc.ec.europa.eu; European Commission Directorate-General Joint Research Center (JRC); Via E.Fermi, 249; Ispra; 21027; Italy (IT); JRC website; http://ies.jrc.ec.eur
opa.eu
NC_GLOBAL#Conventions=CF-1.6
NC_GLOBAL#credit=LST products are generated by the land service of Copernicus, the Earth Observation programme of the European Commission. The LST algorithm, originally developed in the framework of the FP7/Geoland2, is generated from MTSAT/HIMAWARI and GOES data, respectively owned by JMA and NOAA, and combined with the LST product from MSG under copyright EUMETSAT, produced by LSA-SAF.
NC_GLOBAL#date_created=2016-06-22T03:22:01Z
NC_GLOBAL#gcmd_keywords=SURFACE TEMPERATURE
NC_GLOBAL#gemet_keywords=solar radiation
NC_GLOBAL#history=2016-06-22T03:22:01Z - Product generation;
NC_GLOBAL#identifier=urn:cgls:global:lst_v1_0.045degree:LST_201606220100_GLOBE_GEO_V1.2
NC_GLOBAL#inspire_theme=Orthoimagery
NC_GLOBAL#institution=IPMA
NC_GLOBAL#iso19115_topic_categories=climatologyMeteorologyAtmosphere, imageryBaseMapsEarthCover
NC_GLOBAL#long_name=Land Surface Temperature
NC_GLOBAL#name=LST
NC_GLOBAL#orbit_type=GEO
NC_GLOBAL#other_keywords=Global
NC_GLOBAL#parent_identifier=urn:cgls:global:lst_v1_0.045degree
NC_GLOBAL#platform=GOES13, MSG3, HIMAWARI8
NC_GLOBAL#processing_level=L4
NC_GLOBAL#processing_mode=Near Real Time
NC_GLOBAL#product_version=V1.2
NC_GLOBAL#purpose=This product is first designed to fit the requirements of the Global Land component of Land Service of GMES-Copernicus. It can be also useful for all applications related to the environment monitoring.
NC_GLOBAL#references=Product User Manual: http://land.copernicus.eu/global/sites/default/files/products/GIOGL1_PUM_LST_I1.10.pdf
Validation Report: http://land.copernicus.eu/global/sites/default/files/products/GIOGL1_VR_LST_I2.10.pdf
Product page: http://land.copernicus.eu/global/products/lst
NC_GLOBAL#sensor=IMAG, SEVI, AHI
NC_GLOBAL#source=Data was derived from satellite imagery.
NC_GLOBAL#time_coverage_end=2016-06-22T01:30:00Z
NC_GLOBAL#time_coverage_start=2016-06-22T00:30:00Z
NC_GLOBAL#title=Global Land Surface Temperature for 2016-06-22T01:00:00Z
NETCDF_DIM_EXTRA={time}
NETCDF_DIM_time_DEF={1,6}
NETCDF_DIM_time_VALUES=0
time#axis=T
time#long_name=time
time#units=days since 2016-06-22 01:00:00
Corner Coordinates:
Upper Left (-180.0223214, 80.0223214) (180d 1'20.36"W, 80d 1'20.36"N)
Lower Left (-180.0223214, -79.9776824) (180d 1'20.36"W, 79d58'39.66"S)
Upper Right ( 179.9776872, 80.0223214) (179d58'39.67"E, 80d 1'20.36"N)
Lower Right ( 179.9776872, -79.9776824) (179d58'39.67"E, 79d58'39.66"S)
Center ( -0.0223171, 0.0223195) ( 0d 1'20.34"W, 0d 1'20.35"N)
Band 1 Block=200x200 Type=Int16, ColorInterp=Undefined
NoData Value=-8000
Unit Type: Kelvin
Offset: 273.15, Scale:0.01
Metadata:
add_offset=273.15
grid_mapping=crs
NETCDF_DIM_time=0
NETCDF_VARNAME=LST
scale_factor=0.01
units=Kelvin
_FillValue=-8000
So, the important bits are:
gdalinfo NETCDF:"g2_BIOPAR_LST_201606220100_GLOBE_GEO_V1.2.nc":LST |grep Pixel
and
gdalinfo NETCDF:"g2_BIOPAR_LST_201606220100_GLOBE_GEO_V1.2.nc":LST |grep Coordinates -A5
Corner Coordinates:
A fresh Location:
grass -c 'epsg:4326' /geo/grassdb/lst/wgs84
and
g.region -p
projection: 3 (Latitude-Longitude)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 1N
south: 0
west: 0
east: 1E
nsres: 1
ewres: 1
rows: 1
cols: 1
cells: 1
Import using r.in.gdal, _without_ any of `-l` or `-a` and then I get the
closest to the reported spatial resolution. Else, with `-a`, for
example, the spatial resolution is not as close to the "original" one.
Makes sense?
r.in.gdal in=NETCDF:"g2_BIOPAR_LST_201606220300_GLOBE_GEO_V1.2.nc":LST output=g2_BIOPAR_LST_201606220300_GLOBE_GEO_V1.2.nc_LST -o
WARNING: Datum <unknown> not recognised by GRASS and no parameters found
Over-riding projection check
360 degree EW extent is exceeded by 0.000192261 cells
Importing raster map <g2_BIOPAR_LST_201606220300_GLOBE_GEO_V1.2.nc_LST>...
100%
Here,
r.info g2_BIOPAR_LST_201606220300_GLOBE_GEO_V1.2.nc_LST -g
360 degree EW extent is exceeded by 0.00019226 cells
north=80.0223214291667
south=-79.9776823855556
east=179.977687153889
west=-180.022321429167
nsres=0.0446428582072328
ewres=0.0446428582072241
rows=3584
cols=8064
cells=28901376
datatype=CELL
ncats=0
Then, setting the region:
g.region raster=g2_BIOPAR_LST_201606220300_GLOBE_GEO_V1.2.nc_LST -pg
projection=3
zone=0
n=80.0223214291667
s=-79.9776823855556
w=-180.022321429167
e=179.977687153889
rows=3584
cols=8064
cells=28901376
Better to cut off the west side (?):
g.region raster=g2_BIOPAR_LST_201606220100_GLOBE_GEO_V1.2.nc_LST -pag w=-180 e=180
projection=3
zone=0
n=80.0223214291667
s=-79.9776823855556
w=-180
e=180
ewres=0.0446428571428571
rows=3584
cols=8064
cells=28901376
How does this look like? We had this questions not along ago.
Nikos
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180925/91a52024/attachment.sig>
