[GRASS-user] d.mon displays box on startup
    Anna Petrášová
    kratochanna at gmail.com
    Wed Sep 26 11:27:06 PDT 2018
On Wed, Sep 26, 2018 at 1:50 PM Huidae Cho <grass4u at gmail.com> wrote:
> This is a great feature, but I was wondering why it turns red on zoom
> in/out.
I think it changes color depending if you are zoomed inside or outside of
the region. I find this behavior little bit confusing, perhaps just having
one color would be enough, and maybe don't show it when you are zoomed
inside?
Anna
On Tue, Sep 25, 2018 at 4:32 PM Markus Neteler <neteler at osgeo.org> wrote:
>> On Tue, Sep 25, 2018 at 10:28 PM Veronica Andreo <veroandreo at gmail.com>
>> wrote:
>> > That's the computational region limits which are now visible by default
>> in Map display and wx monitors.
>> > However, I agree that an option to make it invisible as before would
>> make sense.
>> Just disable it at left bottom of the display window -> the trick is that
>> you need to *first* switch to "Show comp. extent" which isn't obvious:
>> [image: image.png]
>> > You can open a ticket for this
>> Not needed :)
>> But I think that the "Show computational extent" should always be there.
>> Maybe a ticket for that wish?
> +1
>> Markus
>> PS: sorry for HTML email
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
> Huidae Cho, Ph.D., PE, M.ASCE, CFM, GISP
> Open Source GIS Developer, GRASS GIS Development Team
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180926/ac8a1fc6/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180926/ac8a1fc6/attachment.png>
