[GRASS-user] d.mon displays box on startup
Huidae Cho
grass4u at gmail.com
Wed Sep 26 12:47:31 PDT 2018
Ok, so blue means the current display is the full computational region
(OK). Red means the current display is a subset of the region (zoomed in,
OK). What about when you zoom out and the display contains and is bigger
than the computational region? It is still red. Not blue even if you are
seeing the full region. The last case confuses me. When is it red or blue?
Thanks,
Huidae
Huidae Cho, Ph.D., P.E. (MD), M.ASCE, CFM, GISP
https://idea.isnew.info
Sent from my phone
On Wed, Sep 26, 2018, 2:27 PM Anna Petrášová <kratochanna at gmail.com> wrote:
> On Wed, Sep 26, 2018 at 1:50 PM Huidae Cho <grass4u at gmail.com> wrote:
>> This is a great feature, but I was wondering why it turns red on zoom
>> in/out.
> I think it changes color depending if you are zoomed inside or outside of
> the region. I find this behavior little bit confusing, perhaps just having
> one color would be enough, and maybe don't show it when you are zoomed
> inside?
> Anna
> On Tue, Sep 25, 2018 at 4:32 PM Markus Neteler <neteler at osgeo.org> wrote:
>>> On Tue, Sep 25, 2018 at 10:28 PM Veronica Andreo <veroandreo at gmail.com>
>>> wrote:
>>> > That's the computational region limits which are now visible by
>>> default in Map display and wx monitors.
>>> > However, I agree that an option to make it invisible as before would
>>> make sense.
>>> Just disable it at left bottom of the display window -> the trick is
>>> that you need to *first* switch to "Show comp. extent" which isn't obvious:
>>> [image: image.png]
>>> > You can open a ticket for this
>>> Not needed :)
>>> But I think that the "Show computational extent" should always be there.
>>> Maybe a ticket for that wish?
>> +1
>>> Markus
>>> PS: sorry for HTML email
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/grass-user
>> Huidae Cho, Ph.D., PE, M.ASCE, CFM, GISP
>> Open Source GIS Developer, GRASS GIS Development Team
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180926/e12cca93/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20180926/e12cca93/attachment.png>
