[GRASS-user] cannot install extension on Windows 10
Mira Kattwinkel
kattwinkel-mira at uni-landau.de
Tue Apr 16 06:02:51 PDT 2019
Hello,
yes, I assumed that the metadata is available, but on my system they
seem to be not found. And I do not know what settings to change. What
would be the correct proxy settings?
Indeed, the installation was successful, I can use the extension.
However Settings / Addons extensions / Manage installed extensions gives
me an empty list.
Any ideas?
Thanks a lot, Mira
On 15/04/2019 20.20, Martin Landa wrote:
> Hi,
> po 15. 4. 2019 v 18:18 odesílatel Mira Kattwinkel
> <kattwinkel-mira at uni-landau.de> napsal:
>> For example g.extension extension=r.hydrodem operation=add
>> Updating addons metadata file...
>> ERROR: Unable to read addons metadata file from the remote server:
>> [Errno socket error] [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify
>> failed (_ssl.c:661)
>> WARNING: NO addons metadate available. Addons metadate file not updated.
> hm, metadata seems to be available [0]. I tested installing r.hydrodem
> on my Windows 10 machine. No error, addons installed, possible to
> launch. Something related to proxy or?
>> Installation of <r.hydrodem> successfully finished (it is not!)
> Are you sure about that? Binary package [1] is available. Have you
> tried to launch the module?
> Ma
> [0]https://grass.osgeo.org/addons/grass7/modules.xml
> [1]https://wingrass.fsv.cvut.cz/grass76/x86_64/addons/grass-7.6.0/r.hydrodem.zip
Dr. Mira Kattwinkel
Quantitative Landscape Ecology
Institute for Environmental Sciences
University of Koblenz-Landau
Fortstraße 7
76829 Landau
Germany
Phone: + 49 6341 280-31553
Office: Building I, Room 2.02
