[GRASS-user] grass-7.9 does not find numpy
Rich Shepard rshepard at appl-ecosys.com
Thu Aug 15 12:39:08 PDT 2019
On Thu, 15 Aug 2019, Vincent Bain wrote:
> perhaps related:
> https://lists.osgeo.org/pipermail/grass-user/2019-July/080547.html
Vincent,
Thanks for the URL, but it's not the same issue. There was no numpy to
upgrade.
Normally I build and install packages using the SlackBuilds.org scripts. For
reasons we could not explain, numpy3, scipy3, and python3-matplotlib refused
to build.
Needing these tools I used the command 'pip3 install numpy' because this
syntax tells pip3 to install numpy3 in the python-3.7/site-packages/
directory.
Regards,
Rich
