[GRASS-user] Compiling GRASS GIS on Debian Buster
Vincent Bain bain at toraval.fr
Thu Jul 25 07:30:49 PDT 2019
My self-reply:
sometimes python pip management tool can look tricky to amateurs like
me: a basic "pip install numpy" told me numpy was already installed.
For an effective upgrade of any package one should rather type:
python -m pip install --upgrade SomePackage
(source: python 2.7.16 doc)
Then GRASS starts and runs like a charm!
Hope this helps folks who meet the same issue.
Bye,
Vincent.
Le jeudi 25 juillet 2019 à 09:26 +0200, Vincent Bain a écrit :
> Hi,
> since I upgraded my Debian system to version 10 (buster), I'm not
> able
> to get GRASS working.
> I pulled the latest version from Git main source code repository. The
> usual compilation process runs apparently fine. When launching
> grass77
> from a terminal, the startup screen appears, and lets me pick
> location/mapset, but when starting GRASS session, the gui can't
> start.
> It throws the following error message:
>    wxnviz.py: This module requires the NumPy module, which could not
> be
>    imported. It probably is not installed [...]
> whereas NumPy is properly installed:
>    pip list | grep numpy
> returns:
>    numpy                              1.12.1
> Has anyone experienced such issue?
> Thank you,
> Vincent.
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
