[GRASS-user] GRASSBIN environment variable
Stefan Blumentrath
Stefan.Blumentrath at nina.no
Fri Aug 16 01:00:08 PDT 2019
Hi Alex,
Yes indeed. Would be nice to avoid that.
There is actually an open pull request about it:
https://github.com/zarch/grass-session/pull/12/files
However, I guess a completely version independent solution would be preferable...
With Python 3 shutil.which() will be available also on Windows, however, in OSGeo4W, a version independent "grass.bat" does not seem to be available.
So, currently, for Windows, it is inevitable to include versions. Could be done like this:
def get_grassbin():
"""Find GRASS GIS startup binary"""
from shutil import which
grassbin = which('grass')
if not grassbin:
for v in range(71, 80):
grassbin_version = which('grass{}'.format(v))
if grassbin_version:
grassbin = grassbin_version
return grassbin
get_grassbin()
Not sure when the GRASSBIN variable is set, I guess during startup of GRASS. So when you run grass-session from within GRASS the variable should be set (just guessing though)...
Cheers
Stefan
From: grass-user <grass-user-bounces at lists.osgeo.org> On Behalf Of Moody, Alex
Sent: fredag 16. august 2019 01:00
To: grass-user at lists.osgeo.org
Subject: [GRASS-user] GRASSBIN environment variable
Hi all - I am trying out the grass-session package for the first time and am having issues with the GRASSBIN environment variable. It looks like the grass-session I was able to download references grass75svn.bat. I'm onto grass76.
I was able to get around this in a python session with os.environ['GRASSBIN']=D:\<mypath>\grass76.bat, but it'd be nice to not have to do that.
If I run "set GRASS" from the command line, I see that GRASSBIN=D:\<mypath>\grass75svn.bat even GRASS_VERSION=7.6.1
Where is the GRASSBIN variable set? I've been looking around and can't seem to find it.
Cheers,
Alex
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190816/090bcb7c/attachment-0001.html>
