[GRASS-user] question on Stray light Landsat 8 data
Gabriel Cotlier
gabiklm01 at gmail.com
Tue Aug 20 12:33:35 PDT 2019
Dear Markus,
Thanks a lot for your response and explanation.
Changing the region to w=179:59:45W e=180:00:15E, am I not only avoiding
the warning, but also changing the layers to be physically correct, right?
Thanks again for your help.
regards,
Gabriel
On Tue, Aug 20, 2019 at 4:24 PM Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> Dear Gabriel,
> On Tue, Aug 20, 2019 at 12:19 AM Gabriel Cotlier <gabiklm01 at gmail.com>
> wrote:
> > Dear Markus,
> > Thanks a lot for the clarification and explanation, your response was
> indeed helpful.
> > I got for all maps in the mapset I used, for both the DMSP original
> raster layers and the intercallibrated rasrer layers the following:
> > r.info map= name_of_raster_map
> > 360 degree EW extent is exceeded by 1 cells
> > Which, following what you said before in your response I understand
> makes it correct region, right?
> this region is correct considering the resolution with is now exactly 30
> arc seconds.
> this region is not correct considering that 360 degree EW extent is
> exceeded by 1 cell. The first column from 180:00:15W to 179:59:45W and the
> last column from 179:59:45E to 180:00:15E spatially overlap, the first and
> last column of DMSP are duplicates with regard to their location. If you
> want to avoid this warning, you can set the region to w=179:59:45W
> e=180:00:15E.
> Markus M
> > Another question I wanted to ask is: how to know whether the operation
> of intercallibration was correctly done, for tha I thought maybe thare is
> the a place from where I can corroborate whether the min and max values of
> each intercallibrated raster layer is correct?
> > I'm attaching the log of all the files I got from 'r.info' command in
> it there appears always for the region '360 degree EW extent is exceeded by
> 1 cells' and also the min and max value of each intercallibrated raster
> layer.
> > So as to know if I got all the raster correctly intercallibrated maybe
> checking if the min and max value for each intercallibrated corresponds
> correctly is there a place where I can check that?
> > Maybe according to my attached log file is possible to know if all the
> intercallibration operation was correctly done and thus the layers are
> ready for further study and analysis.
> > Thanks a lot again for your help.
> > Kind regards,
> > Gabriel
> > Virus-free. www.avast.com
> > On Mon, Aug 19, 2019 at 4:41 PM Markus Metz <
> markus.metz.giswork at gmail.com> wrote:
> >> On Mon, Aug 19, 2019 at 12:05 AM Gabriel Cotlier <gabiklm01 at gmail.com>
> wrote:
> >> > Hello,
> >> > My question is how does it influence the fact that it say:
> >> > 360 degree EW extent is exceeded by 0.999827 cells
> >> this is caused by the truncated resolution of 0.008333333300000
> >> with a corrected resolution of 00:00:30, the message is
> >> considering the EW extents of 180:00:15W to 180:00:15E, that means that
> the first column from 180:00:15W to 179:59:45W and the last column from
> 179:59:45E to 180:00:15E spatially overlap, the first and last column of
> DMSP are duplicates with regard to their location. If you want to avoid
> this warning, you can set the region to w=179:59:45W e=180:00:15E.
> >> Note that the recommended way to set a computational region to a raster
> map is g.region rast=name_of_raster_map. After that, as for DMSP, you might
> want to adjust the computational region to your needs, e.g. a smaller
> region of interest, or restrict it to 360 degrees EW extent in case the
> raster map is exceeding 360 degrees EW extent.
> >> HTH,
> >> Markus M
> >> > while when I loaded a first file I defined a region as
> >> > which is exactly I suppose the correct region for the DMSP data....
> then after loading the other layers it appears:
> >> > Thanks a lot
> >> > Gabriel
> >> > On Sun, Aug 18, 2019 at 6:54 PM Gabriel Cotlier <gabiklm01 at gmail.com>
> wrote:
> >> >> Hello, another question, regarding i.nightlights.intercalibration,
> can I run this code as python package/lbrary loading it from Spyder or
> Jupiter Notebook instead of using GRASS interface, if so how is a
> convenient way to install i.nightlights.intercalibration in python using
> Spyder?
> >> >> Thanks a lot.
> >> >> Gabriel
> >> >> On Sat, Aug 17, 2019 at 4:54 PM Gabriel Cotlier <gabiklm01 at gmail.com>
> wrote:
> >> >>> Dear Nikos.
> >> >>> After a long time I'm trying to reproduce a routine I have for
> doing intercallibratrion of DMSP 1992-2012 but for some reason It doesn't
> work to me. I think is because the problem between the region of the layers
> 30 arc sec should resolution be from 0.008333333300000 to
> 0.008333333333333, i.e. exactly 30 arc-seconds? and the computational
> region be the same ? I got stuck on how to set it to work... from the side
> of the region setting.
> >> >>> However in addition my routing also has a for loop which does not
> work ok as well.
> >> >>> I would appreciate a lot of you can give it a look and tell me how
> to make it work...
> >> >>> Thanks a lot in advance
> >> >>> Kind regards,
> >> >>> Gabriel
> >> >>> # complete routine for intercalliration of DSMP/OLS light stable
> product
> >> >>> import grass.script as gscript
> >> >>> import os
> >> >>> import os,glob
> >> >>> # get working directory
> >> >>> print os.getcwd()
> >> >>> # change working directory where raster files are
> >> >>> os.chdir('C:\\Users\\Gabriel\\Documents\\grassdata\\lights')
> >> >>> # see files in directory
> >> >>> ls
> >> >>> # import all raster files to grass --- here is a kind of
> problem...???
> >> >>> for tif_file in glob.glob("*.tif"):
> >> >>> new_rast = os.path.splitext(tif_file)[0]
> >> >>> grass.run_command("r.in.gdal", flags="a", input=tif_file,
> output=new_rast)
> >> >>> # get info of one of the imported raster
> >> >>> r.info map=F121996
> >> >>> # run intercalliration algorithm
> image=F101992,F101993,F101994,F121994,F121995,F121996,F121997,F121998,F121999,F141997,F141998,F141999,F142000,F142001,F142002,F142003,F152000,F152001,F152002,F152003,F152004,F152005,F152006,F152007,F162004,F162005,F162006,F162007,F162008,F162009,F182010,F182011,F182012,F182013
> suffix=c model=elvidge2014 -t
> >> >>> # correct general region adjust to raster file --- here the region
> is exactly 30 arc for the raster as I could see....
> >> >>> g.region raster=F121996
> >> >>> # cerate a list of rasters in the mapset
> >> >>> # rastlist=grass.read_command("g.list",type="rast").split()
> >> >>> rasters = grass.read_command('g.list', type='raster').splitlines()
> >> >>> os.chdir('C:\\Users\\Gabriel\\Desktop\\out')
> >> >>> # save rasters in mapset to file
> >> >>> for raster in rasters:
> >> >>> grass.run_command('r.out.gdal', input=raster, output=raster +
> '.tiff', format='GTiff')
> >> >>> On Wed, Aug 22, 2018 at 10:06 AM Gabriel Cotlier <
> gabiklm01 at gmail.com> wrote:
> >> >>>> Dear Nikos,
> >> >>>> Thanks a lot for your answer and the orientation.
> >> >>>> The information and the link are very useful.
> >> >>>> Kind regards,
> >> >>>> Gabriel
> >> >>>> On Wed, Aug 22, 2018 at 5:19 AM Nikos Alexandris <
> nik at nikosalexandris.net> wrote:
> >> >>>>> * Gabriel Cotlier <gabiklm01 at gmail.com> [2018-08-21 12:00:24
> -0300]:
> >> >>>>> >Dear Nikos and GRASS users,
> >> >>>>> >I would like to ask if nonetheless the effect due to "stray
> light" the
> >> >>>>> >*i.landsat8.swlst* code for split window is still applicable to
> Landsat 8
> >> >>>>> >data and whether these error is specially visible on water
> bodies? and
> >> >>>>> >whether band 10 is better than band 11 in terms of correction
> processing
> >> >>>>> >for Level -1 data products?
> >> >>>>> >Thanks a lot.
> >> >>>>> >Kind regards,
> >> >>>>> >Gabriel
> >> >>>>> Dear Gabriel,
> >> >>>>> for details and references, refer to
> https://landsat.gsfc.nasa.gov/landsat-8-thermal-data-ghost-free-after-stray-light-exorcism/
> >> >>>>> Make sure you use the newest Level-1 Collection 1 Landsat 8
> products.
> >> >>>>> I use `i.landsat8.swlst` and plan to improve it further.
> >> >>>>> However, whether to prefer a Split-Window based approach, or
> another
> >> >>>>> Single-Channel one, depends on what you want to do. Think of
> spatial
> >> >>>>> extent and coverage of various land (cover) types, temporal extent
> >> >>>>> and more.
> >> >>>>> Thermal remote sensing is hard(er) also because it's hard to get
> >> >>>>> ground-truth data sets so as to validate LST estimations.
> >> >>>>> Nikos
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190820/f743b96d/attachment-0001.html>
