[GRASS-user] Copy projection to another location
Ken Mankoff
mankoff at gmail.com
Mon Aug 26 23:26:59 PDT 2019
On 2019-08-26 at 22:38 +02, Rich Shepard <rshepard at appl-ecosys.com> wrote...
> can I change the CRS for an existing location or only when it's being
> created?
You can, but it is rare that you should do it, and a fairly low-level operation. It is required in some edge cases, like when setting up a rotated pole coordinate system.
What is your use-case or intended goal/behavior/setup? Perhaps there are easier and more appropriate methods.
-k.
