[GRASS-user] Copy projection to another location
Rich Shepard
rshepard at appl-ecosys.com
Tue Aug 27 07:44:57 PDT 2019
On Tue, 27 Aug 2019, Ken Mankoff wrote:
> You can, but it is rare that you should do it, and a fairly low-level
> operation. It is required in some edge cases, like when setting up a
> rotated pole coordinate system.
Ken,
That's what I thought
> What is your use-case or intended goal/behavior/setup? Perhaps there are
> easier and more appropriate methods.
When I start spatial analyses on a new project I want to set the location
using that state's 'official' CRS. While I thought I had done this when I
created the project location the PROJ_INFO file did not reflect this.
Thanks,
Rich
