[GRASS-user] question on i.nightlights.intercalibration
Gabriel Cotlier
gabiklm01 at gmail.com
Tue Aug 27 05:27:52 PDT 2019
while for individual raster maps I get:
[image: image.png]
On Tue, Aug 27, 2019 at 9:25 AM Gabriel Cotlier <gabiklm01 at gmail.com> wrote:
> What should I do in this case?
> On Tue, Aug 27, 2019 at 9:24 AM Gabriel Cotlier <gabiklm01 at gmail.com>
> wrote:
>> Dear Markus,
>> here is my log of the command, "g.region -d -u -p":
>> (Tue Aug 27 09:23:26 2019)
>> g.region -d -u -p
>> 360 degree EW extent is exceeded by 1.99983 cells
>> projection: 3 (Latitude-Longitude)
>> zone: 0
>> datum: wgs84
>> ellipsoid: wgs84
>> north: 75:00:29.99892N
>> south: 65:00:29.999064S
>> west: 180:00:29.997408W
>> east: 180:00:29.997408E
>> nsres: 0:00:30
>> ewres: 0:00:30
>> rows: 16802
>> cols: 43202
>> cells: 725880004
>> (Tue Aug 27 09:23:26 2019) Command finished (0 sec)
>> On Mon, Aug 26, 2019 at 4:01 PM Markus Metz <
>> markus.metz.giswork at gmail.com> wrote:
>>> On Mon, Aug 26, 2019 at 1:14 AM Gabriel Cotlier <gabiklm01 at gmail.com>
>>> wrote:
>>> > Dear Markus,
>>> > I uninstall and reinstall grass 7.6.1 64 bits and still my log for the
>>> commands
>>> > g.region -p
>>> > and
>>> > g.region -p n=75:00:15N s=65:00:15S w=179:59:45W e=180:00:15E
>>> res=00:00:30
>>> > are respectively :
>>> > (Sun Aug 25 20:01:47 2019)
>>> > g.region -p
>>> > zone: 0
>>> > datum: wgs84
>>> > ellipsoid: wgs84
>>> > north: 75:00:15N
>>> > south: 65:00:15S
>>> > west: 179:59:45W
>>> > east: 180:00:15E
>>> > nsres: 0:00:30
>>> > ewres: 0:00:30
>>> > rows: 16801
>>> > cols: 43200
>>> > cells: 725803200
>>> > (Sun Aug 25 20:01:47 2019) Command finished (0 sec)
>>> > (Sun Aug 25 20:02:10 2019)
>>> res=00:00:30
>>> Strange, the region defined with "n=75:00:15N s=65:00:15S w=179:59:45W
>>> e=180:00:15E res=00:00:30" should not cause a message like
>>> "360 degree EW extent is exceeded by 1.99983 cells"
>>> Maybe the default region has strange settings. What is the output of
>>> "g.region -d -u -p" ?
>>> Markus M
>>> > zone: 0
>>> > datum: wgs84
>>> > ellipsoid: wgs84
>>> > north: 75:00:15N
>>> > south: 65:00:15S
>>> > west: 179:59:45W
>>> > east: 180:00:15E
>>> > nsres: 0:00:30
>>> > ewres: 0:00:30
>>> > rows: 16801
>>> > cols: 43200
>>> > cells: 725803200
>>> > (Sun Aug 25 20:02:10 2019) Command finished (0 sec)
>>> > Are the resulting intercallibrated layers ready for further use
>>> outside grass exported as GeoTIFF or I need to get inside grass without any
>>> messages that 360 degree EW extent is exceeded for the layer to be OK?
>>> > further more I would like to ask if maybe the max and min for
>>> intercallibtated layer are somewhere already available to check whether the
>>> max and min I got are correct?
>>> > Thanks a lot for your help.
>>> > Regards,
>>> > Gabriel
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190827/4e3fac03/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190827/4e3fac03/attachment-0001.png>
