[GRASS-user] question on i.nightlights.intercalibration
Gabriel Cotlier
gabiklm01 at gmail.com
Tue Aug 27 05:32:58 PDT 2019
imported into QGIS layer visible and the of the layer properties are:
[image: image.png]
On Tue, Aug 27, 2019 at 9:27 AM Gabriel Cotlier <gabiklm01 at gmail.com> wrote:
> while for individual raster maps I get:
> [image: image.png]
> On Tue, Aug 27, 2019 at 9:25 AM Gabriel Cotlier <gabiklm01 at gmail.com>
> wrote:
>> What should I do in this case?
>> On Tue, Aug 27, 2019 at 9:24 AM Gabriel Cotlier <gabiklm01 at gmail.com>
>> wrote:
>>> Dear Markus,
>>> here is my log of the command, "g.region -d -u -p":
>>> (Tue Aug 27 09:23:26 2019)
>>> g.region -d -u -p
>>> 360 degree EW extent is exceeded by 1.99983 cells
>>> projection: 3 (Latitude-Longitude)
>>> zone: 0
>>> datum: wgs84
>>> ellipsoid: wgs84
>>> north: 75:00:29.99892N
>>> south: 65:00:29.999064S
>>> west: 180:00:29.997408W
>>> east: 180:00:29.997408E
>>> nsres: 0:00:30
>>> ewres: 0:00:30
>>> rows: 16802
>>> cols: 43202
>>> cells: 725880004
>>> (Tue Aug 27 09:23:26 2019) Command finished (0 sec)
>>> On Mon, Aug 26, 2019 at 4:01 PM Markus Metz <
>>> markus.metz.giswork at gmail.com> wrote:
>>>> On Mon, Aug 26, 2019 at 1:14 AM Gabriel Cotlier <gabiklm01 at gmail.com>
>>>> wrote:
>>>> > Dear Markus,
>>>> > I uninstall and reinstall grass 7.6.1 64 bits and still my log for
>>>> the commands
>>>> > g.region -p
>>>> > and
>>>> > g.region -p n=75:00:15N s=65:00:15S w=179:59:45W e=180:00:15E
>>>> res=00:00:30
>>>> > are respectively :
>>>> > (Sun Aug 25 20:01:47 2019)
>>>> > g.region -p
>>>> > zone: 0
>>>> > datum: wgs84
>>>> > ellipsoid: wgs84
>>>> > north: 75:00:15N
>>>> > south: 65:00:15S
>>>> > west: 179:59:45W
>>>> > east: 180:00:15E
>>>> > nsres: 0:00:30
>>>> > ewres: 0:00:30
>>>> > rows: 16801
>>>> > cols: 43200
>>>> > cells: 725803200
>>>> > (Sun Aug 25 20:01:47 2019) Command finished (0 sec)
>>>> > (Sun Aug 25 20:02:10 2019)
>>>> res=00:00:30
>>>> Strange, the region defined with "n=75:00:15N s=65:00:15S w=179:59:45W
>>>> e=180:00:15E res=00:00:30" should not cause a message like
>>>> "360 degree EW extent is exceeded by 1.99983 cells"
>>>> Maybe the default region has strange settings. What is the output of
>>>> "g.region -d -u -p" ?
>>>> Markus M
>>>> > zone: 0
>>>> > datum: wgs84
>>>> > ellipsoid: wgs84
>>>> > north: 75:00:15N
>>>> > south: 65:00:15S
>>>> > west: 179:59:45W
>>>> > east: 180:00:15E
>>>> > nsres: 0:00:30
>>>> > ewres: 0:00:30
>>>> > rows: 16801
>>>> > cols: 43200
>>>> > cells: 725803200
>>>> > (Sun Aug 25 20:02:10 2019) Command finished (0 sec)
>>>> > Are the resulting intercallibrated layers ready for further use
>>>> outside grass exported as GeoTIFF or I need to get inside grass without any
>>>> messages that 360 degree EW extent is exceeded for the layer to be OK?
>>>> > further more I would like to ask if maybe the max and min for
>>>> intercallibtated layer are somewhere already available to check whether the
>>>> max and min I got are correct?
>>>> > Thanks a lot for your help.
>>>> > Regards,
>>>> > Gabriel
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190827/76563247/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190827/76563247/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190827/76563247/attachment-0003.png>
