[GRASS-user] Creating location using EPSG code
Ken Mankoff mankoff at gmail.com
Wed Aug 28 01:45:02 PDT 2019
On 2019-08-27 at 16:42 +02, Rich Shepard <rshepard at appl-ecosys.com> wrote...
> While I know that regions are subsets within the bounds of the CRS
> defined for a location I don't recall importing a vector or raster map
> and not being able to zoom to its extents before explicitly setting a
> region.
Perhaps in the earlier work the region was set w/o import based on how you created the location? If you created the location using "-c SomeGeoTiff.tif", then the region is set to that file. If you create it with "-c EPSG:nnnn", it doesn't know extent, resolution, etc. and the defaults, as you saw, are all 0 or 1.
  -k.
