[GRASS-user] Creating location using EPSG code
Rich Shepard
rshepard at appl-ecosys.com
Wed Aug 28 05:27:24 PDT 2019
On Wed, 28 Aug 2019, Ken Mankoff wrote:
> Perhaps in the earlier work the region was set w/o import based on how you
> created the location? If you created the location using "-c
> SomeGeoTiff.tif", then the region is set to that file. If you create it
> with "-c EPSG:nnnn", it doesn't know extent, resolution, etc. and the
> defaults, as you saw, are all 0 or 1.
Ken,
Yes, this explains the difference. Almost always prior project locations
were created using a .adf or .prj file with the CRS and the balance of the
files with the data.
Thanks for the insight.
Best regards,
Rich
