[GRASS-user] Datum not recognized by Grass
Helmut Kudrnovsky
hellik at web.de
Tue Dec 3 11:22:21 PST 2019
Markus Neteler wrote
> Hi,
> On Mon, Dec 2, 2019 at 9:49 AM Zoltan Szecsei <
> zoltans at .co
> > wrote:
>> Hi,
>> I'm using EPSG 2932 and QGIS etc all are OK with it.
>> I have installed everything using OSGeo4W64, so how come Grass does not
>> use the same projections database (as QGis etc)?
>> (and please can I have a pointer as to how to introduce EPSG 2932 to
>> Grass 7.8.1)
>> Thanks and regards,
>> Zoltan
>> ******** Running against:
>> D:\GDBroad_tiles\shp_road_poly_few\23103770_road_poly.shp
>> WARNING: Datum
> <Qatar_National_Datum_1995>
> not recognised by GRASS and
>> no parameters found
> Is it possible that you have a PROJ software version mixup?
> I tried on my Linux box:
> grass78 -c epsg:2932 ~/grassdata/test_2932
> Starting GRASS GIS...
> Creating new GRASS GIS location
> <test_2932>
> Cleaning up temporary files...
> __________ ___ __________ _______________
> / ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
> / / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
> / /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
> \____/_/ |_/_/ |_/____/____/ \____/___//____/
> Welcome to GRASS GIS 7.8.2dev (ad4836c73)
> GRASS 7.8.2dev (test_2932):~ > g.proj -w
> PROJCS["QND95 / Qatar National Grid",
> GEOGCS["QND95",
> DATUM["Qatar_National_Datum_1995",
> SPHEROID["International 1924",6378388,297,
> AUTHORITY["EPSG","7022"]],
> TOWGS84[-119.4248,-303.65872,-11.00061,1.164298,0.174458,1.096259,3.657065],
> AUTHORITY["EPSG","6614"]],
> PRIMEM["Greenwich",0,
> AUTHORITY["EPSG","8901"]],
> UNIT["degree",0.0174532925199433,
> AUTHORITY["EPSG","9122"]],
> AUTHORITY["EPSG","4614"]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["latitude_of_origin",24.45],
> PARAMETER["central_meridian",51.21666666666667],
> PARAMETER["scale_factor",0.99999],
> PARAMETER["false_easting",200000],
> PARAMETER["false_northing",300000],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]],
> AXIS["Easting",EAST],
> AXIS["Northing",NORTH],
> AUTHORITY["EPSG","2932"]]
> # The versions here:
> GRASS 7.8.2dev (test_2932):~ > g.version -rge
> version=7.8.2dev
> date=2019
> revision=ad4836c73
> build_date=2019-11-28
> build_platform=x86_64-pc-linux-gnu
> build_off_t_size=8
> libgis_revision=00000
> libgis_date="?"
> proj=5.2.0
> gdal=2.3.2
> geos=3.7.1
> sqlite=3.30.0
> Looks all fine.
> Please check if an old PROJ 4 is installed which might confuse things.
with
C:\>g.version -rge
version=7.8.1
date=2019
revision=c865432c9
build_date=2019-11-10
build_platform=x86_64-w64-mingw32
build_off_t_size=8
libgis_date="?"
proj=6.2.1
gdal=3.0.2
geos=3.8.0
sqlite=3.29.0
I get with the location wizzard:
File
"C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\location_wizard\wizard.py",
line 1607, in OnPageChanging
self.parent.parent, transforms=ret)
File
"C:\OSGEO4~1\apps\grass\grass78\gui\wxpython\location_wizard\dialogs.py",
line 617, in __init__
transforms = '---\n\n0\nDo not apply any datum transformations\n\n' +
transforms
TypeError: can only concatenate str (not "bytes") to str
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
