[GRASS-user] Datum not recognized by Grass
Helmut Kudrnovsky
hellik at web.de
Tue Dec 3 11:26:53 PST 2019
Markus Neteler wrote
> Hi,
> On Mon, Dec 2, 2019 at 9:49 AM Zoltan Szecsei <
> zoltans at .co
> > wrote:
>> Hi,
>> I'm using EPSG 2932 and QGIS etc all are OK with it.
>> I have installed everything using OSGeo4W64, so how come Grass does not
>> use the same projections database (as QGis etc)?
>> (and please can I have a pointer as to how to introduce EPSG 2932 to
>> Grass 7.8.1)
>> Thanks and regards,
>> Zoltan
>> ******** Running against:
>> D:\GDBroad_tiles\shp_road_poly_few\23103770_road_poly.shp
>> WARNING: Datum
> <Qatar_National_Datum_1995>
> not recognised by GRASS and
>> no parameters found
> Is it possible that you have a PROJ software version mixup?
> I tried on my Linux box:
> grass78 -c epsg:2932 ~/grassdata/test_2932
> Starting GRASS GIS...
> Creating new GRASS GIS location
> <test_2932>
> Cleaning up temporary files...
> __________ ___ __________ _______________
> / ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
> / / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
> / /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
> \____/_/ |_/_/ |_/____/____/ \____/___//____/
> Welcome to GRASS GIS 7.8.2dev (ad4836c73)
> GRASS 7.8.2dev (test_2932):~ > g.proj -w
> PROJCS["QND95 / Qatar National Grid",
> GEOGCS["QND95",
> DATUM["Qatar_National_Datum_1995",
> SPHEROID["International 1924",6378388,297,
> AUTHORITY["EPSG","7022"]],
> TOWGS84[-119.4248,-303.65872,-11.00061,1.164298,0.174458,1.096259,3.657065],
> AUTHORITY["EPSG","6614"]],
> PRIMEM["Greenwich",0,
> AUTHORITY["EPSG","8901"]],
> UNIT["degree",0.0174532925199433,
> AUTHORITY["EPSG","9122"]],
> AUTHORITY["EPSG","4614"]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["latitude_of_origin",24.45],
> PARAMETER["central_meridian",51.21666666666667],
> PARAMETER["scale_factor",0.99999],
> PARAMETER["false_easting",200000],
> PARAMETER["false_northing",300000],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]],
> AXIS["Easting",EAST],
> AXIS["Northing",NORTH],
> AUTHORITY["EPSG","2932"]]
C:\>g.proj -w
GEOGCS["QND95",
PARAMETER["central_meridian",51.2166666666667],
UNIT["metre",1,
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
