[GRASS-user] error compiling grass 7.8.2 on centos 7
    Laura Poggio
    laura.poggio at gmail.com
    Wed Dec 18 23:12:07 PST 2019
Dear list,
I am trying to compile grass 7.8.2 on an HPC cluster using centos 7 as
operative system. I can not install binaries. I need to compile from source.
The python version I am using is Python 3.7.4
The configure and the make are working fine. However I get the following
errors at the make install stage:
rm /home/user/grass//grass78/etc/fontcap
rm: cannot remove ‘/home/user/grass//grass78/etc/fontcap’: No such file or
directory
make[1]: [real-install] Error 1 (ignored)
make /home/user/grass//grass78/etc/fontcap
make[2]: Entering directory `/home/user/grass/grass-7.8.2'
make[2]: *** No rule to make target
`/home/user/grass/grass-7.8.2/dist.x86_64-pc-linux-gnu/etc/fontcap', needed
by `/home/user/grass//grass78/etc/fontcap'.  Stop.
make[2]: Leaving directory `/home/user/grass/grass-7.8.2'
make[1]: *** [real-install] Error 2
make[1]: Leaving directory `/home/user/grass/grass-7.8.2'
make: *** [install] Error 2
Am I missing some dependencies in the fonts?
Is the python version ok or should I use a slightly older 3.x one?
are there any recommendations for the gcc version to use?
Thank you very much for your help in advance.
Best wishes
Laura
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20191219/736e7552/attachment.html>
