[GRASS-user] error compiling grass 7.8.2 on centos 7
Laura Poggio laura.poggio at gmail.com
Fri Dec 20 03:03:46 PST 2019
Dear all,
I managed to remove the error by specifying --without-zstd.
Thanks a lot!
Laura
On Fri, 20 Dec 2019 at 10:48, Laura Poggio <laura.poggio at gmail.com> wrote:
> Dear Markus,
> the path to the GRASS source (the directory where I compile) is
> /home/user/grass/grass-7.8.2/
> I get the same when I try to compile with -prefix=/home/user/local/
> Thanks!
> Laura
> On Fri, 20 Dec 2019 at 09:22, Markus Metz <markus.metz.giswork at gmail.com>
> wrote:
>> On Fri, Dec 20, 2019 at 7:47 AM Laura Poggio <laura.poggio at gmail.com>
>> wrote:
>> > Dear Markus,
>> > thanks
>> > Below my configure (grass 7.6.1 compiles fine with a similar configure.)
>> > ./configure \
>> > -prefix=/home/user/grass/ \
>> is it possible that prefix and path to the GRASS source are identical?
>> This will not work and cause errors when running "make install". In this
>> case, prefix must be set to another location, e.g. /home/user/local if you
>> do not want or can not use the default /usr/local.
>> Just a guess,
>> Markus M
>> > --enable-64bit
>> --with-fftw-includes=/cm/shared/apps/fftw/openmpi/gcc/64/3.3.7/include/ \
>> > --with-fftw-libs=/cm/shared/apps/fftw/openmpi/gcc/64/3.3.7/lib/ \
>> --with-freetype-includes=/home/user/grass/freetypes/freetype-2.9.1/include/
>> > --with-netcdf --with-geos --with-blas --with-lapack --with-postgres \
>> > --with-zstd-libs=/home/user/grass/zstd/zstd-1.4.0/lib/ \
>> > --with-zstd-includes=/home/user/grass/zstd/zstd-1.4.0/lib/
>> > The freetype and zstd are in my home because they are not available on
>> the cluster, so I had to create them locally.
>> > If I may, I add an additional question: which is the right option in
>> configure to point to a specific version of proj? --with-proj-libs?
>> > Thanks a lot
>> > Laura
>> > On Thu, 19 Dec 2019 at 23:36, Markus Neteler <neteler at osgeo.org> wrote:
>> >> On Thu, Dec 19, 2019 at 8:12 AM Laura Poggio <laura.poggio at gmail.com>
>> wrote:
>> >> > Dear list,
>> >> > I am trying to compile grass 7.8.2 on an HPC cluster using centos 7
>> as operative system. I can not install binaries.
>> >> Just to understand: for policy reasons?
>> >> > I need to compile from source.
>> >> > The python version I am using is Python 3.7.4
>> >> > The configure and the make are working fine.
>> >> Importantly, pls post your "configure" command to better understand
>> >> the error below:
>> >> > However I get the following errors at the make install stage:
>> >> > rm /home/user/grass//grass78/etc/fontcap
>> >> > rm: cannot remove ‘/home/user/grass//grass78/etc/fontcap’: No such
>> file or directory
>> >> > make[1]: [real-install] Error 1 (ignored)
>> >> > make /home/user/grass//grass78/etc/fontcap
>> >> > make[2]: Entering directory `/home/user/grass/grass-7.8.2'
>> >> > make[2]: *** No rule to make target
>> `/home/user/grass/grass-7.8.2/dist.x86_64-pc-linux-gnu/etc/fontcap', needed
>> by `/home/user/grass//grass78/etc/fontcap'.  Stop.
>> >> > make[2]: Leaving directory `/home/user/grass/grass-7.8.2'
>> >> > make[1]: *** [real-install] Error 2
>> >> > make[1]: Leaving directory `/home/user/grass/grass-7.8.2'
>> >> > make: *** [install] Error 2
>> >> > Am I missing some dependencies in the fonts?
>> >> ... probably in the configure step.
>> >> > Is the python version ok or should I use a slightly older 3.x one?
>> >> That should be fine.
>> >> > are there any recommendations for the gcc version to use?
>> >> No special recommendations.
>> >> Best wishes
>> >> Markus
>> > _______________________________________________
>> > grass-user mailing list
>> > grass-user at lists.osgeo.org
>> > https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20191220/8eb02274/attachment.html>
