[GRASS-user] error compiling grass 7.8.2 on centos 7
Markus Metz
markus.metz.giswork at gmail.com
Fri Dec 20 04:14:18 PST 2019
On Fri, Dec 20, 2019 at 12:03 PM Laura Poggio <laura.poggio at gmail.com>
wrote:
> Dear all,
> I managed to remove the error by specifying --without-zstd.
is it possible that your custom path to zstd libs
/home/user/grass/zstd/zstd-1.4.0/lib
is not in LD_LIBRARY_PATH?
That would explain it.
Markus M
> Thanks a lot!
> Laura
> On Fri, 20 Dec 2019 at 10:48, Laura Poggio <laura.poggio at gmail.com> wrote:
>> Dear Markus,
>> the path to the GRASS source (the directory where I compile) is
>> /home/user/grass/grass-7.8.2/
>> I get the same when I try to compile with -prefix=/home/user/local/
>> Thanks!
>> Laura
>> On Fri, 20 Dec 2019 at 09:22, Markus Metz <markus.metz.giswork at gmail.com>
wrote:
>>> On Fri, Dec 20, 2019 at 7:47 AM Laura Poggio <laura.poggio at gmail.com>
wrote:
>>> > Dear Markus,
>>> > thanks
>>> > Below my configure (grass 7.6.1 compiles fine with a similar
configure.)
>>> > ./configure \
>>> > -prefix=/home/user/grass/ \
>>> is it possible that prefix and path to the GRASS source are identical?
This will not work and cause errors when running "make install". In this
case, prefix must be set to another location, e.g. /home/user/local if you
do not want or can not use the default /usr/local.
>>> Just a guess,
>>> Markus M
>>> > --enable-64bit
--with-fftw-includes=/cm/shared/apps/fftw/openmpi/gcc/64/3.3.7/include/ \
>>> > --with-fftw-libs=/cm/shared/apps/fftw/openmpi/gcc/64/3.3.7/lib/ \
--with-freetype-includes=/home/user/grass/freetypes/freetype-2.9.1/include/
>>> > --with-netcdf --with-geos --with-blas --with-lapack --with-postgres \
>>> > --with-zstd-libs=/home/user/grass/zstd/zstd-1.4.0/lib/ \
>>> > --with-zstd-includes=/home/user/grass/zstd/zstd-1.4.0/lib/
>>> > The freetype and zstd are in my home because they are not available
on the cluster, so I had to create them locally.
>>> > If I may, I add an additional question: which is the right option in
configure to point to a specific version of proj? --with-proj-libs?
>>> > Thanks a lot
>>> > Laura
>>> > On Thu, 19 Dec 2019 at 23:36, Markus Neteler <neteler at osgeo.org>
wrote:
>>> >> On Thu, Dec 19, 2019 at 8:12 AM Laura Poggio <laura.poggio at gmail.com>
wrote:
>>> >> > Dear list,
>>> >> > I am trying to compile grass 7.8.2 on an HPC cluster using centos
7 as operative system. I can not install binaries.
>>> >> Just to understand: for policy reasons?
>>> >> > I need to compile from source.
>>> >> > The python version I am using is Python 3.7.4
>>> >> > The configure and the make are working fine.
>>> >> Importantly, pls post your "configure" command to better understand
>>> >> the error below:
>>> >> > However I get the following errors at the make install stage:
>>> >> > rm /home/user/grass//grass78/etc/fontcap
>>> >> > rm: cannot remove ‘/home/user/grass//grass78/etc/fontcap’: No such
file or directory
>>> >> > make[1]: [real-install] Error 1 (ignored)
>>> >> > make /home/user/grass//grass78/etc/fontcap
>>> >> > make[2]: Entering directory `/home/user/grass/grass-7.8.2'
>>> >> > make[2]: *** No rule to make target
`/home/user/grass/grass-7.8.2/dist.x86_64-pc-linux-gnu/etc/fontcap', needed
by `/home/user/grass//grass78/etc/fontcap'. Stop.
>>> >> > make[2]: Leaving directory `/home/user/grass/grass-7.8.2'
>>> >> > make[1]: *** [real-install] Error 2
>>> >> > make[1]: Leaving directory `/home/user/grass/grass-7.8.2'
>>> >> > make: *** [install] Error 2
>>> >> > Am I missing some dependencies in the fonts?
>>> >> ... probably in the configure step.
>>> >> > Is the python version ok or should I use a slightly older 3.x one?
>>> >> That should be fine.
>>> >> > are there any recommendations for the gcc version to use?
>>> >> No special recommendations.
>>> >> Best wishes
>>> >> Markus
>>> > _______________________________________________
>>> > grass-user mailing list
>>> > grass-user at lists.osgeo.org
>>> > https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20191220/32dac8ac/attachment.html>
