[GRASS-user] How to generate a vector graphics file from GRASS CLI?
st_kiefer at web.de st_kiefer at web.de
Mon Feb 4 00:21:07 PST 2019
Hi Ken,
unfotunately i have not tested that so far, but outside grass I used virtual raster many times for this purpose. You might try to harness r.buildvrt to combine different raster-layer (or have a look for GDAL .vrt-files). So i use this to keep smal raster files but get large combined extends. This should work for overlappings as well. But as I said, I did not verify this.
https://grass.osgeo.org/grass77/manuals/r.buildvrt.html
cheers
Stefan
> Ken Mankoff <mankoff at gmail.com> hat am 2. Februar 2019 um 11:51 geschrieben:
> Hello,
> On 2019-01-29 at 11:48 +0100, st_kiefer at web.de wrote...
> > Give it a try. ps.map is not that complicated. The manual page even
> > offers an out of the box template for instant results (just scroll to
> > the end). And if you get familiar with that tool you can produce very
> > convincing graphics for publications, with graphically additions of
> > your liking.
> One more ps.map question. What is the best/easiest method to patch together multiple rasters with different colors?
> I have two raster basemaps plus a velocity raster map.
> One basemap is the output of r.shade (a colored shaded relief map).
> One basemap is the output of r.relief (a grayscale shaded map)
> The velocity raster has its own color scale.
> I'd like all three in ps.map, but understand there is a one-raster limitation (any good reason for this?). How do I patch them but maintain distinct colors?
> Thanks,
>   -k.
