[GRASS-user] 3D raster remove voxels above DEM
Moritz Lennert
mlennert at club.worldonline.be
Wed Feb 6 05:37:33 PST 2019
On 6/02/19 14:02, Francois Chartier wrote:
> Thanks Moritz
> My goal is to summarize the steps for 3d interpolation at the end of the
> process. it took me a year to get here and still have a few more steps
> to do which i will contact the User list for.
> I am actually doing this as part of a 2nd master thesis with le Cnam in
> Paris as continuing education, so i will formalize the process.
> The voxels above the dem are not Null values in this interpolation as
> the vvolrst interpolates the data within the full 'footprint' of the
> g.region; is there a possibility to constrain the interpolation to in
> between the DEM and lower surface, by setting a more customized Region
> than a Block?
You could try r3.mask.
Moritz
> On Feb 6, 2019 04:45, "Moritz Lennert" <mlennert at club.worldonline.be
> <mailto:mlennert at club.worldonline.be>> wrote:
> Hi François,
> Thanks for sharing the solution you found. From your first mail it was
> clear to me what these voxels above the DEM contained. NULL values ?
> It would be great if you could summarize all your experience working on
> 3D data in GRASS GIS in the wiki, at least by amending
> https://grasswiki.osgeo.org/wiki/Help_with_3D with your additions or
> corrections ? This would be very helpful many others.
> Moritz
> On 6/02/19 03:46, Francois Chartier wrote:
> > See attached screenshot, I was able to remove voxels above the
> DEM and
> > below bedrock surface using r3.out.vtk and selecting export as
> > *pointdata (p)* not voxels. If exported as a Voxel from
> r3.out.vtk, the
> > voxel file did not open properly in Paraview could be due to size of
> > file. I changed option to export as points and it is working.
> > grid resolution is 5 x 5 x 1 m over 4km x 4 km x 65 m thickness
> approx.
> > (actual thickness varies between DEM and top of rock).
> > r3.out.vtk -p -s input=jan27551tens100 at Toronto
> output=C:\Users\Francois
> > Chartier\Documents\GeoModel\WorkingFile\Feb6_VTK_Pts
> top=GTADEM at Toronto
> > bottom=rock at PERMANENT
> > Le mar. 5 févr. 2019 à 21:20, Francois Chartier
> <fra.chartier at gmail.com <mailto:fra.chartier at gmail.com>
> > <mailto:fra.chartier at gmail.com <mailto:fra.chartier at gmail.com>>>
> the DEM
> > and below bedrock surface using r3.out.vtk and selecting
> export as
> r3.out.vtk,
> > the voxel file did not open properly in Paraview could be due to
> > size of file. I changed option to export as points and it is
> working.
> > approx. (actual thickness varies between DEM and top of rock).
> > top=GTADEM at Toronto bottom=rock at PERMANENT
> > Le dim. 3 févr. 2019 à 16:42, Francois Chartier
> <mailto:fra.chartier at gmail.com <mailto:fra.chartier at gmail.com>>> a
> écrit :
> > Hi,
> > I would like to remove voxels located at a higher elevation
> > than DEM.
> > I have been trying r3.mapcalc without sucess.
> > Does the XY resolutions of both raster have to the same?
> > any ideas how to do this?
> > Thanks
> > Francois
> > grass-user mailing list
> > grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> > https://lists.osgeo.org/mailman/listinfo/grass-user
