[GRASS-user] 3D raster remove voxels above DEM
Francois Chartier
fra.chartier at gmail.com
Wed Feb 6 05:02:24 PST 2019
Thanks Moritz
My goal is to summarize the steps for 3d interpolation at the end of the
process. it took me a year to get here and still have a few more steps to
do which i will contact the User list for.
I am actually doing this as part of a 2nd master thesis with le Cnam in
Paris as continuing education, so i will formalize the process.
The voxels above the dem are not Null values in this interpolation as the
vvolrst interpolates the data within the full 'footprint' of the g.region;
is there a possibility to constrain the interpolation to in between the DEM
and lower surface, by setting a more customized Region than a Block?
On Feb 6, 2019 04:45, "Moritz Lennert" <mlennert at club.worldonline.be> wrote:
Hi François,
Thanks for sharing the solution you found. From your first mail it was
clear to me what these voxels above the DEM contained. NULL values ?
It would be great if you could summarize all your experience working on
3D data in GRASS GIS in the wiki, at least by amending
https://grasswiki.osgeo.org/wiki/Help_with_3D with your additions or
corrections ? This would be very helpful many others.
Moritz
On 6/02/19 03:46, Francois Chartier wrote:
> See attached screenshot, I was able to remove voxels above the DEM and
> below bedrock surface using r3.out.vtk and selecting export as
> *pointdata (p)* not voxels. If exported as a Voxel from r3.out.vtk, the
> voxel file did not open properly in Paraview could be due to size of
> file. I changed option to export as points and it is working.
> grid resolution is 5 x 5 x 1 m over 4km x 4 km x 65 m thickness approx.
> (actual thickness varies between DEM and top of rock).
> r3.out.vtk -p -s input=jan27551tens100 at Toronto output=C:\Users\Francois
> Chartier\Documents\GeoModel\WorkingFile\Feb6_VTK_Pts top=GTADEM at Toronto
> bottom=rock at PERMANENT
> Le mar. 5 févr. 2019 à 21:20, Francois Chartier <fra.chartier at gmail.com
> and below bedrock surface using r3.out.vtk and selecting export as
> the voxel file did not open properly in Paraview could be due to
> size of file. I changed option to export as points and it is working.
> approx. (actual thickness varies between DEM and top of rock).
> top=GTADEM at Toronto bottom=rock at PERMANENT
> Le dim. 3 févr. 2019 à 16:42, Francois Chartier
> <fra.chartier at gmail.com <mailto:fra.chartier at gmail.com>> a écrit :
> Hi,
> I would like to remove voxels located at a higher elevation
> than DEM.
> I have been trying r3.mapcalc without sucess.
> Does the XY resolutions of both raster have to the same?
> any ideas how to do this?
> Thanks
> Francois
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190206/99c682d6/attachment-0001.html>
