[GRASS-user] Unable to read .prj file
Helmut Kudrnovsky
hellik at web.de
Sat Feb 9 02:12:44 PST 2019
>> Trying to create a new location using a shapefile .prj. GRASS tells me it
>> cannot read the file using gdal.
>I also find that a bit annoying. Indeed, you need to specify the .shp
>file and not the .prj file (which doesn't make much sense).
just tried it here with winGRASS 7.6 and winGRASS 7.7.svn, defining and
creating a new location with Rich's prj-file works here.
(Sat Feb 09 11:12:03 2019)
g.proj -j
+proj=utm
+no_defs
+zone=11
+a=6378137
+rf=298.257222101
+towgs84=0.000,0.000,0.000
+to_meter=1
(Sat Feb 09 11:12:03 2019) Befehl ausgeführt (0 Sek)
(Sat Feb 09 11:12:22 2019)
g.proj -w
PROJCS["UTM Zone 11, Northern Hemisphere",
GEOGCS["grs80",
DATUM["North_American_Datum_1983",
SPHEROID["Geodetic_Reference_System_1980",6378137,298.257222101]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",-117],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",0],
UNIT["Meter",1]]
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
