[GRASS-user] Raster - assign interpolated values into range
Moritz Lennert
mlennert at club.worldonline.be
Tue Feb 26 04:30:00 PST 2019
On 26/02/19 02:23, Francois Chartier wrote:
> doesnt work with 3d raster. only takes in 2d. i did it with access, more
> tedious but it works. i should be able to do this with the attribute
> table directly but havent tried yet.
A raster doesn't have an attribute table, so this is not a solution.
r3.mapcalc with nested rules such as this should work:
if(map >=0.01 && map < 0.5, 0.25, if(map < 1, 0.75, if(etc)))
But I do believe that r.reclass and r.recode are fundamental modules
that should also exist for r3. So, I would suggest filling in an
enhancement request ticket in trac.
Moritz
> On Mon, Feb 25, 2019, 05:57 Moritz Lennert <mlennert at club.worldonline.be
> <mailto:mlennert at club.worldonline.be> wrote:
> On 23/02/19 23:16, Francois Chartier wrote:
> > What about if i dont want constant spacing but at certain ranges?
> Have you tried r.recode as Vero suggested ?
> Moritz
> > Le sam. 23 févr. 2019 à 11:00, Veronica Andreo
> <veroandreo at gmail.com <mailto:veroandreo at gmail.com>
> > <mailto:veroandreo at gmail.com <mailto:veroandreo at gmail.com>>> a
> écrit :
> > El sáb., 23 feb. 2019 12:17, Markus Metz
> > <markus.metz.giswork at gmail.com
> <mailto:markus.metz.giswork at gmail.com>
> <mailto:markus.metz.giswork at gmail.com>>> escribió:
> > On Sat, Feb 23, 2019 at 1:45 PM Francois Chartier
> > <fra.chartier at gmail.com <mailto:fra.chartier at gmail.com>
> <mailto:fra.chartier at gmail.com <mailto:fra.chartier at gmail.com>>> wrote:
> > > Hi,
> > > After creating a raster (2 or 3d) is there a way that
> > interpolated values (floats) can be assigned a specific value
> > based on range. example: 0.01, 0.2 0.52, 0.67, 0.99, values
> > between 0.01 and 0.5 assign 0.25; values between 0.5 and 1,
> > assign 0.75.
> > if you want to assign values to 0.25, 0.75, 1.25, 1.75, etc.,
> > i.e. new values with a constant spacing of 0.5, you can use
> > r.mapcalc "output = round(input, 0.5, 0.25)"
> > Ah! So cool!! 8)
> > grass-user mailing list
> > grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> > https://lists.osgeo.org/mailman/listinfo/grass-user
