[GRASS-user] Raster - assign interpolated values into range
Francois Chartier
fra.chartier at gmail.com
Tue Feb 26 05:11:44 PST 2019
thanks, i will submit a ticket in trac.
On Tue, Feb 26, 2019, 07:33 Moritz Lennert <mlennert at club.worldonline.be
wrote:
> On 26/02/19 02:23, Francois Chartier wrote:
> > doesnt work with 3d raster. only takes in 2d. i did it with access, more
> > tedious but it works. i should be able to do this with the attribute
> > table directly but havent tried yet.
> A raster doesn't have an attribute table, so this is not a solution.
> r3.mapcalc with nested rules such as this should work:
> if(map >=0.01 && map < 0.5, 0.25, if(map < 1, 0.75, if(etc)))
> But I do believe that r.reclass and r.recode are fundamental modules
> that should also exist for r3. So, I would suggest filling in an
> enhancement request ticket in trac.
> Moritz
> > On Mon, Feb 25, 2019, 05:57 Moritz Lennert <mlennert at club.worldonline.be
> > <mailto:mlennert at club.worldonline.be> wrote:
> > On 23/02/19 23:16, Francois Chartier wrote:
> > > What about if i dont want constant spacing but at certain ranges?
> > Have you tried r.recode as Vero suggested ?
> > Moritz
> > > Le sam. 23 févr. 2019 à 11:00, Veronica Andreo
> > <veroandreo at gmail.com <mailto:veroandreo at gmail.com>
> > > <mailto:veroandreo at gmail.com <mailto:veroandreo at gmail.com>>> a
> > écrit :
> > > El sáb., 23 feb. 2019 12:17, Markus Metz
> > > <markus.metz.giswork at gmail.com
> > <mailto:markus.metz.giswork at gmail.com>
> > <mailto:markus.metz.giswork at gmail.com>>> escribió:
> > > On Sat, Feb 23, 2019 at 1:45 PM Francois Chartier
> > > <fra.chartier at gmail.com <mailto:fra.chartier at gmail.com>
> > <mailto:fra.chartier at gmail.com <mailto:fra.chartier at gmail.com>>>
> wrote:
> > > > Hi,
> > > > After creating a raster (2 or 3d) is there a way that
> > > interpolated values (floats) can be assigned a specific
> value
> > > based on range. example: 0.01, 0.2 0.52, 0.67, 0.99,
> values
> > > between 0.01 and 0.5 assign 0.25; values between 0.5 and
> 1,
> > > assign 0.75.
> > > if you want to assign values to 0.25, 0.75, 1.25, 1.75,
> etc.,
> > > i.e. new values with a constant spacing of 0.5, you can
> use
> > > r.mapcalc "output = round(input, 0.5, 0.25)"
> > > Ah! So cool!! 8)
> > > _______________________________________________
> > > grass-user mailing list
> > > grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> > > https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190226/06628b72/attachment.html>
