[GRASS-user] ascii decode special character
Veronica Andreo
veroandreo at gmail.com
Thu Jan 3 03:16:43 PST 2019
Hi Frank,
Good that you solved it :)
In any case, I would recommend you to update your grass version. There have
been quite some changes since August last year in trunk (Dev version).
Moreover, I think the ps.map issue could be solved by saving the psmap
instructions with a different encoding, no need to change language because
of that. Check the last paragraph under Notes in the manual [0].
HTH,
Vero
[0] https://grass.osgeo.org/grass77/manuals/ps.map.html
El jue., 3 ene. 2019 6:45, Frank David <frank.david at geophom.fr> escribió:
> Hi Markus,
> Hi Frank,
> Am Mi., 2. Jan. 2019, 16:56 hat Frank David <frank.david at geophom.fr>
> geschrieben:
>> Hello all,
>> I wish a very nice year to every GRASS user and also for GRASS
>> developments !
> Happy New Year!
> I met a decoding problem with "v.db.select map=my_vector
>> columns=my_name" when GRASS meet some special characters in the string
>> of my_name field. The string value is "Côte de la Bouchère".
>> See below the error message :
>> Traceback (most recent call last):
>> File
>> "/usr/local/grass-7.5.svn/gui/wxpython/gui_core/goutput.py",
>> line 472, in OnCmdOutput
>> self.cmdOutput.AddStyledMessage(message, type)
>> File
>> line 771, in AddStyledMessage
>> self.AddTextWrapped(message, wrap=None)
>> File
>> line 722, in AddTextWrapped
>> self.AddText(txt)
>> File "/usr/lib/python2.7/dist-
>> packages/wx-3.0-gtk2/wx/stc.py", line 2041, in AddText
>> return _stc.StyledTextCtrl_AddText(*args, **kwargs)
>> UnicodeDecodeError
>> 'ascii' codec can't decode byte 0xc3 in position 1: ordinal
>> not in range(128)
>> (Wed Jan 2 16:40:24 2019) Command finished (0 sec)
>> Is there anybody who know how I can solve this ? (with GRASS v7.5 on
>> debian9)
> Could you please send the precise version? It looks a bit dated.
> g.version -g
> version=7.5.svn
> date=2018
> revision=r
> build_date=2018-08-10
> build_platform=x86_64-pc-linux-gnu
> build_off_t_size=8
> But I was in en language. If I set in system (or french), it works!
> In fact, I'm using sometimes English GUI because the scale bar text in
> psmap is not well coded and is displayed kilomÄ"tre, in english kilometer.
> anyway, english GUI should handled special character isn't it ?
> Best regards,
> Frank
> Best
> Markus
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190103/0a5d67c3/attachment.html>
