[GRASS-user] ascii decode special character
Frank David
frank.david at geophom.fr
Thu Jan 3 03:43:30 PST 2019
Hi Vero,
Ok for updating.
Concerning the problem of special character in units (kilometer) scale
bar, we already had a post about that, and encoding in ISO-8859-1 does
not change anything about that (but solve the problem in text string
from user). I think the problem comes from grass code...
I met the same problem with v.label.
Cheers,
Frank
Le 03/01/2019 à 12:16, Veronica Andreo a écrit :
> Hi Frank,
> Good that you solved it :)
> In any case, I would recommend you to update your grass version. There
> have been quite some changes since August last year in trunk (Dev
> version).
> Moreover, I think the ps.map issue could be solved by saving the psmap
> instructions with a different encoding, no need to change language
> because of that. Check the last paragraph under Notes in the manual [0].
> HTH,
> Vero
> [0] https://grass.osgeo.org/grass77/manuals/ps.map.html
> El jue., 3 ene. 2019 6:45, Frank David <frank.david at geophom.fr
> <mailto:frank.david at geophom.fr>> escribió:
> Hi Markus,
>> Hi Frank,
>> Am Mi., 2. Jan. 2019, 16:56 hat Frank David
>> <frank.david at geophom.fr <mailto:frank.david at geophom.fr>> geschrieben:
>> Hello all,
>> I wish a very nice year to every GRASS user and also for GRASS
>> developments !
>> Happy New Year!
>> I met a decoding problem with "v.db.select map=my_vector
>> columns=my_name" when GRASS meet some special characters in
>> the string
>> of my_name field. The string value is "Côte de la Bouchère".
>> See below the error message :
>> Traceback (most recent call last):
>> File
>> "/usr/local/grass-7.5.svn/gui/wxpython/gui_core/goutput.py",
>> line 472, in OnCmdOutput
>> self.cmdOutput.AddStyledMessage(message, type)
>> File
>> line 771, in AddStyledMessage
>> self.AddTextWrapped(message, wrap=None)
>> File
>> line 722, in AddTextWrapped
>> self.AddText(txt)
>> File "/usr/lib/python2.7/dist-
>> packages/wx-3.0-gtk2/wx/stc.py", line 2041, in AddText
>> return _stc.StyledTextCtrl_AddText(*args, **kwargs)
>> UnicodeDecodeError
>> 'ascii' codec can't decode byte 0xc3 in position 1: ordinal
>> not in range(128)
>> (Wed Jan 2 16:40:24 2019) Command finished (0 sec)
>> Is there anybody who know how I can solve this ? (with GRASS
>> v7.5 on
>> debian9)
>> Could you please send the precise version? It looks a bit dated.
>> g.version -g
> version=7.5.svn
> date=2018
> revision=r
> build_date=2018-08-10
> build_platform=x86_64-pc-linux-gnu
> build_off_t_size=8
> But I was in en language. If I set in system (or french), it works!
> In fact, I'm using sometimes English GUI because the scale bar
> text in psmap is not well coded and is displayed kilomÄ"tre, in
> english kilometer.
> anyway, english GUI should handled special character isn't it ?
> Best regards,
> Frank
>> Best
>> Markus
> grass-user mailing list
> grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/grass-user
-------------- section suivante --------------
Une pièce jointe HTML a été nettoyée...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190103/c62a2efb/attachment-0001.html>
