[GRASS-user] ascii decode special character
Veronica Andreo
veroandreo at gmail.com
Thu Jan 3 04:40:09 PST 2019
Hi Frank,
Maybe I do not get what you mean, but changing the encoding for the psmap
file and the running ps.map with the newly saved file helped me with
special characters in Spanish such as accent and ñ. That's what we use
ps.map for, no? Or what do you mean then?
Cheers,
Vero
El jue., 3 ene. 2019 a las 12:43, Frank David (<frank.david at geophom.fr>)
escribió:
> Hi Vero,
> Ok for updating.
> Concerning the problem of special character in units (kilometer) scale
> bar, we already had a post about that, and encoding in ISO-8859-1 does not
> change anything about that (but solve the problem in text string from
> user). I think the problem comes from grass code...
> I met the same problem with v.label.
> Cheers,
> Frank
> Le 03/01/2019 à 12:16, Veronica Andreo a écrit :
> Hi Frank,
> Good that you solved it :)
> In any case, I would recommend you to update your grass version. There
> have been quite some changes since August last year in trunk (Dev version).
> Moreover, I think the ps.map issue could be solved by saving the psmap
> instructions with a different encoding, no need to change language because
> of that. Check the last paragraph under Notes in the manual [0].
> HTH,
> Vero
> [0] https://grass.osgeo.org/grass77/manuals/ps.map.html
> El jue., 3 ene. 2019 6:45, Frank David <frank.david at geophom.fr> escribió:
>> Hi Markus,
>> Hi Frank,
>> Am Mi., 2. Jan. 2019, 16:56 hat Frank David <frank.david at geophom.fr>
>> geschrieben:
>>> Hello all,
>>> I wish a very nice year to every GRASS user and also for GRASS
>>> developments !
>> Happy New Year!
>> I met a decoding problem with "v.db.select map=my_vector
>>> columns=my_name" when GRASS meet some special characters in the string
>>> of my_name field. The string value is "Côte de la Bouchère".
>>> See below the error message :
>>> Traceback (most recent call last):
>>> File
>>> "/usr/local/grass-7.5.svn/gui/wxpython/gui_core/goutput.py",
>>> line 472, in OnCmdOutput
>>> self.cmdOutput.AddStyledMessage(message, type)
>>> File
>>> line 771, in AddStyledMessage
>>> self.AddTextWrapped(message, wrap=None)
>>> File
>>> line 722, in AddTextWrapped
>>> self.AddText(txt)
>>> File "/usr/lib/python2.7/dist-
>>> packages/wx-3.0-gtk2/wx/stc.py", line 2041, in AddText
>>> return _stc.StyledTextCtrl_AddText(*args, **kwargs)
>>> UnicodeDecodeError
>>> 'ascii' codec can't decode byte 0xc3 in position 1: ordinal
>>> not in range(128)
>>> (Wed Jan 2 16:40:24 2019) Command finished (0 sec)
>>> Is there anybody who know how I can solve this ? (with GRASS v7.5 on
>>> debian9)
>> Could you please send the precise version? It looks a bit dated.
>> g.version -g
>> version=7.5.svn
>> date=2018
>> revision=r
>> build_date=2018-08-10
>> build_platform=x86_64-pc-linux-gnu
>> build_off_t_size=8
>> But I was in en language. If I set in system (or french), it works!
>> In fact, I'm using sometimes English GUI because the scale bar text in
>> psmap is not well coded and is displayed kilomÄ"tre, in english kilometer.
>> anyway, english GUI should handled special character isn't it ?
>> Best regards,
>> Frank
>> Best
>> Markus
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190103/fcb5128a/attachment.html>
