[GRASS-user] How to generate a vector graphics file from GRASS CLI?
Veronica Andreo
veroandreo at gmail.com
Tue Jan 29 09:42:40 PST 2019
Hi
El mar., 29 ene. 2019 a las 13:57, Ken Mankoff (<mankoff at gmail.com>)
escribió:
> On 2019-01-29 at 11:48 +0100, st_kiefer at web.de wrote...
> > Give it a try. ps.map is not that complicated. The manual page even
> > offers an out of the box template for instant results (just scroll to
> > the end). And if you get familiar with that tool you can produce very
> > convincing graphics for publications, with graphically additions of
> > your liking.
> You're right - it is easy.
> One issue - I can't reference map at mapset. I have to g.copy map at mapset,map
> and then reference just "map". Am I missing something or is this a real
> limitation?
I just tested with the cartographic composer GUI (g.gui.psmap) and with
command line ps.map, and as long as the other mapset is accessible, no
problems with fully qualified map names, i.e., map at mapset. No need to copy
maps, you can use map at mapset in the instruction file
cheers,
Vero
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190129/de72a6f4/attachment.html>
