[GRASS-user] v.vol.rst - not enough disk space to write temp file
Francois Chartier fra.chartier at gmail.com
Tue Jan 29 15:13:45 PST 2019
I think the problem came from my g.region setting.  under the resolution
tab i was only filling  for example EW, NS and vertical. then i noticed
that the 3d resolution was different when printing g.region and i was
creating for ex in the order of 100 million cells. i solved that by setting
every cell under the resolution tab, even if that means repeating the same
info (perhaps i havent understood something yet), and it works.
for the lighting, i have checked this tab earlier and i recall that u can
onlh change the sun position which then results always in a shaded area
which impacts 3d isosurfaces.
thx
On Tue, Jan 29, 2019, 15:29 Markus Neteler <neteler at osgeo.org wrote:
> On Thu, Jan 17, 2019 at 4:00 AM Francois Chartier
> <fra.chartier at gmail.com> wrote:
> > My solution is to use a smaller model domain with 'only' 16 million
> cells, with grid resolution of 10 x 10 m horizontally, and 1 m vertically.
> Glad you got it running.
> > is there anyway to remove the shade in the 3D view ?
> Under the "Appearance" tab you find
> Lighting for adjusting light source
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190129/8215f7e6/attachment.html>
