[GRASS-user] Build error: git repo master
Rich Shepard
rshepard at appl-ecosys.com
Thu Jul 18 08:37:36 PDT 2019
On Thu, 18 Jul 2019, Markus Metz wrote:
> can you go into any of the subdirs listed, run make and paste the full
> output? I had the same error some hours ago, it was a library in a
> non-standard place that caused the problem.
Markus M,
I started the top of the list of failed builds:
[rshepard at baetis ~/gis/grass/grass_src/lib/raster3d/test]$ make
if [/"/home/rshepard/gis/grass/grass_src/dist.x86_64-pc-linux-gnu/bin/test.raster3d.lib"
/!= "" ] ; then
/GISRC=/home/rshepard/gis/grass/grass_src/dist.x86_64-pc-linux-gnu/demolocation/.grassrc77
/GISBASE=/home/rshepard/gis/grass/grass_src/dist.x86_64-pc-linux-gnu
/PATH="/home/rshepard/gis/grass/grass_src/dist.x86_64-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass_src/dist.x86_64-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass_src/dist.x86_64-pc-linux-gnu/scripts:$PATH"
/PYTHONPATH="/home/rshepard/gis/grass/grass_src/dist.x86_64-pc-linux-gnu/etc/python:/home/rshepard/gis/grass/grass_src/dist.x86_64-pc-linux-gnu/gui/wxpython:$PYTHONPATH"
/LD_LIBRARY_PATH="/home/rshepard/gis/grass/grass_src/dist.x86_64-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass_src/dist.x86_64-pc-linux-gnu/bin:/home/rshepard/gis/grass/grass_src/dist.x86_64-pc-linux-gnu/scripts:/home/rshepard/gis/grass/grass_src/dist.x86_64-pc-linux-gnu/lib:/home/rshepard/gis/grass/grass_src/dist.x86_64-pc-linux-gnu/lib:/usr/lib/qt/lib:"
/LC_ALL=C LANG=C LANGUAGE=C
//home/rshepard/gis/grass/grass_src/dist.x86_64-pc-linux-gnu/bin/test.raster3d.lib
/--html-description < /dev/null | grep -v '</body>\|</html>' >
/test.raster3d.lib.tmp.html ; fi
/home/rshepard/gis/grass/grass_src/dist.x86_64-pc-linux-gnu/bin/test.raster3d.lib:
/ error while loading shared libraries: libgeos-3.7.0.so: cannot open shared
/ object file: No such file or directory
../../../include/Make/Html.make:14: recipe for target 'test.raster3d.lib.tmp.html' failed
make: *** [test.raster3d.lib.tmp.html] Error 1
rm test.raster3d.lib.tmp.html
In case long lines are truncated I've attached the file.
Thanks,
Rich
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190718/d975784f/attachment-0001.txt>
