[GRASS-user] Build error: git repo master
Markus Metz
markus.metz.giswork at gmail.com
Thu Jul 18 08:27:05 PDT 2019
Hi Rich,
On Thu, Jul 18, 2019 at 4:49 PM Rich Shepard <rshepard at appl-ecosys.com>
wrote:
> On Thu, 18 Jul 2019, Markus Neteler wrote:
> > Please check in the lines above (there must have been output in the
> > terminal in which you compile) for error messages.
> Markus,
> My apologies for not doing this before.
> > It is defined in include/Make/... (I'm traveling and have no computer
> > available to check).
> > I think it is simply "error.log".
> Actually, there are errors in almost every source file. I tee'd the build
> process (82K xz compressed tarball) and copied the end to the attached
file
> which shows all the errors. Haven't see this before, only the occasional
> single file that bombed.
can you go into any of the subdirs listed, run make and paste the full
output?
I had the same error some hours ago, it was a library in a non-standard
place that caused the problem.
Markus M
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190718/9bef27dc/attachment.html>
