[GRASS-user] Points to area workflow
Rich Shepard
rshepard at appl-ecosys.com
Sat Jul 20 11:30:34 PDT 2019
On Sat, 20 Jul 2019, Thomas Adams wrote:
> How are you seeing that points convert to an area? An area encompassing
> the points?? In which case you probably want v.hull (
> https://grass.osgeo.org/grass76/manuals/v.hull.html).
> One further suggestion, consider changing your variable names for, uh,
> readability??
Tom,
The points, as the file name suggests, are the corners of the analysis area.
I don't want to calculate a convex hull on four corner points, I want
boundary lines connecting the corners, then the area within the boundary.
Thanks,
Rich
