[GRASS-user] WINGrass: g.extension – Not found
    Maria Cecilia Zalazar
    zalazarmariacecilia at gmail.com
    Mon Jul 22 12:20:22 PDT 2019
Hello again, when I run r.landscape.evol, now I get this error:
  File "C:\Users\USUARIO\AppData\Roaming\GRASS7\addons/scrip
ts/r.landscape.evol.py", line 665, in <module>
    f = file(statsout, 'wt')
IOError: [Errno 13] Permission denied:
u'PERMANENT_levol_lsevol_stats.csv'
it´s appears as if the path to the rules file must be error or missing?
My user is administrator.
Thanks for your help!
El lun., 22 de jul. de 2019 a la(s) 11:23, Maria Cecilia Zalazar (
zalazarmariacecilia at gmail.com) escribió:
> I could do it! Thank you very much for your help
> El lun., 22 de jul. de 2019 a la(s) 11:04, Helmut Kudrnovsky (
> hellik at web.de) escribió:
>> Maria Cecilia Zalazar wrote
>> > I would like to know if there are news about installing extensions from
>> > the
>> > repository. I´m ussing Grass 7.6.1 in Windows.
>> > However, I´ve download zip file (r.landscape.evol) and I tried to
>> install
>> > it manually:
>> > g.extension extension=r.landscape.evol
>> > url=C:\OSGeo4W64\apps\grass\r.landscape.evol.zip
>> > Downloading precompiled GRASS Addons
>> > <r.landscape.evol>
>> > ERROR: Extension
>> > <r.landscape.evol>
>> >  not found
>> > I tried different paths, / instead \, but i can´t get it...
>> still work in progress.
>> as a workaround:
>> ° download zipped r.landscape.evol from here [1]:
>> https://wingrass.fsv.cvut.cz/grass76/x86_64/addons/latest/r.landscape.evol.zip
>> ° unzip
>> ° copy the content of the subfolders into the equivalent subfolders under
>> C:\Users\YourUserName\AppData\Roaming\GRASS7\addons
>> ° start a winGRASS session and start the addon in the command line
>> HTH
>> [1] https://wingrass.fsv.cvut.cz/grass76/x86_64/addons/latest/
>> best regards
>> Helmut
>> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190722/09ca355e/attachment.html>
