[GRASS-user] WINGrass: g.extension – Not found
    Maria Cecilia Zalazar
    zalazarmariacecilia at gmail.com
    Mon Jul 22 12:51:40 PDT 2019
I was able to fixed it. Thanks very much at all!
El lun., 22 de jul. de 2019 a la(s) 16:20, Maria Cecilia Zalazar (
zalazarmariacecilia at gmail.com) escribió:
> Hello again, when I run r.landscape.evol, now I get this error:
> Traceback (most recent call last):
>   File "C:\Users\USUARIO\AppData\Roaming\GRASS7\addons/scrip
> ts/r.landscape.evol.py", line 665, in <module>
>     f = file(statsout, 'wt')
> IOError: [Errno 13] Permission denied:
> u'PERMANENT_levol_lsevol_stats.csv'
> it´s appears as if the path to the rules file must be error or missing?
> My user is administrator.
> Thanks for your help!
> El lun., 22 de jul. de 2019 a la(s) 11:23, Maria Cecilia Zalazar (
>> I could do it! Thank you very much for your help
>> El lun., 22 de jul. de 2019 a la(s) 11:04, Helmut Kudrnovsky (
>> hellik at web.de) escribió:
>>> Maria Cecilia Zalazar wrote
>>> > I would like to know if there are news about installing extensions from
>>> > the
>>> > repository. I´m ussing Grass 7.6.1 in Windows.
>>> > However, I´ve download zip file (r.landscape.evol) and I tried to
>>> install
>>> > it manually:
>>> > g.extension extension=r.landscape.evol
>>> > url=C:\OSGeo4W64\apps\grass\r.landscape.evol.zip
>>> > Downloading precompiled GRASS Addons
>>> > <r.landscape.evol>
>>> > ERROR: Extension
>>> > <r.landscape.evol>
>>> >  not found
>>> > I tried different paths, / instead \, but i can´t get it...
>>> still work in progress.
>>> as a workaround:
>>> ° download zipped r.landscape.evol from here [1]:
>>> https://wingrass.fsv.cvut.cz/grass76/x86_64/addons/latest/r.landscape.evol.zip
>>> ° unzip
>>> ° copy the content of the subfolders into the equivalent subfolders under
>>> C:\Users\YourUserName\AppData\Roaming\GRASS7\addons
>>> ° start a winGRASS session and start the addon in the command line
>>> HTH
>>> [1] https://wingrass.fsv.cvut.cz/grass76/x86_64/addons/latest/
>>> best regards
>>> Helmut
>>> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190722/2aca20f1/attachment.html>
