[GRASS-user] 7.7.dev: No raster map displays [UPDATE]
Helmut Kudrnovsky
hellik at web.de
Wed Jul 24 12:54:10 PDT 2019
Helmut Kudrnovsky wrote
> Rich Shepard wrote
>> On Wed, 24 Jul 2019, Helmut Kudrnovsky wrote:
>>> If you want that analytical extent matches your vector extent _and_ the
>>> DEM
>>> resolution, use g.region -a raster=DEM vector=yourvector.
>> Helmut,
>> I've read the manual and missed understanding that it can be defined by
>> both
>> raster and vector maps.
>> I don't think this is necessary. I can set the region to the DEM and the
>> MASK to the vector map so r.slope.aspect and r.flow will operate only
>> within
>> the mask regardless of the overall region size. Unless I'm mistaken about
>> the function of the MASK.
>> Best regards,
>> Rich
>> grass-user mailing list
>> grass-user at .osgeo
>> https://lists.osgeo.org/mailman/listinfo/grass-user
> As you mentioned in your mail above:
>>DEM resolution: 3 3
>>analytical_area resolution: 2.99763360 3.00134608
> '>g.region vect=analytical_area res=3 -p' did not change the floating
> >point
> {values to integer 3s.
> Do you see your mismatch?
> If you do g.region vect=yourvector res=whatever it tries to close as
> possible to the resolution, but it's not aligned with your raster.
> Some raster modules will issue some warnings or errors.
> Moritz gave you a good explanation about region settings, masks etc aorund
> the end of last year.
> best regards
> Helmut
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
See here:
https://www.mail-archive.com/grass-user@lists.osgeo.org/msg36351.html
best regards
Helmut
