[GRASS-user] 7.7.dev: save maps in GUI?
Rich Shepard
rshepard at appl-ecosys.com
Thu Jul 25 13:00:26 PDT 2019
On Thu, 25 Jul 2019, Eric Patton wrote:
> Probably the closest thing to what you're looking for that exists is the
> cartographic composer and ps.map. You can easily add your map decorations
> to the ps.map script for reuse.
Eric,
I've used the cartographic composer and ps.map working from the grass shell.
When planning the output map structure it's often quicker to use the GUI
where layers can be added and removed and properties changed quickly and
without running the output through ps.map.
Thanks,
Rich
