[GRASS-user] question on i.landsat.toa function
Gabriel Cotlier
gabiklm01 at gmail.com
Sun Jun 16 13:19:02 PDT 2019
Dear Vero,
I could finally load the landsat 8 L1C data, is just two bands 4 and 5 for
NDVI calculation, didn't created a mapset just used PERMANT, but my
workflow is
Step 1 - DN>Radiance with
*i.landsat.toar *
Step* 2- Raniance> Surface_Reflectance with i.atcorr *using different
methods DOS2 and DOS4 to compare
*For step 1: to get radinace from DN*
A) set working directory where the data is:
cd
"C:\Users\Gabriel\Documents\grassdata\LC08_L1TP_227083_20180315_20180320_01_T1"
B) calculate Radiance for each band separately :
i.landsat.toar -r
input=LC08_L1TP_227083_20180315_20180320_01_T1_B4 at PERMANENT
output=LC08_L1TP_227083_20180315_20180320_01_T1_B4_toar
metfile=C:\Users\Gabriel\Documents\grassdata\LC08_L1TP_227083_20180315_20180320_01_T1\LC08_L1TP_227083_20180315_20180320_01_T1_MTL.txt
sensor=oli8 date=2018-03-15 sun_elevation=45.06637424
product_date=2018-03-20
however go the error was:
[image: image.png]
appears not to be reading the data from PERMANENT?
Thanks a lot
Gabriel
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190616/b1d08e8e/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190616/b1d08e8e/attachment.png>
