[GRASS-user] question on i.landsat.toa function
Gabriel Cotlier
gabiklm01 at gmail.com
Sun Jun 16 13:30:07 PDT 2019
Hello,
I tried it to get radiance from command line too but had an error as well
with metadata recognition:
[image: image.png]
Thanks a lot
On Sun, Jun 16, 2019 at 5:19 PM Gabriel Cotlier <gabiklm01 at gmail.com> wrote:
> Dear Vero,
> I could finally load the landsat 8 L1C data, is just two bands 4 and 5 for
> NDVI calculation, didn't created a mapset just used PERMANT, but my
> workflow is
> Step 1 - DN>Radiance with
> *i.landsat.toar *
> Step* 2- Raniance> Surface_Reflectance with i.atcorr *using different
> methods DOS2 and DOS4 to compare
> *For step 1: to get radinace from DN*
> A) set working directory where the data is:
> cd
> "C:\Users\Gabriel\Documents\grassdata\LC08_L1TP_227083_20180315_20180320_01_T1"
> B) calculate Radiance for each band separately :
> i.landsat.toar -r
> input=LC08_L1TP_227083_20180315_20180320_01_T1_B4 at PERMANENT
> output=LC08_L1TP_227083_20180315_20180320_01_T1_B4_toar
> metfile=C:\Users\Gabriel\Documents\grassdata\LC08_L1TP_227083_20180315_20180320_01_T1\LC08_L1TP_227083_20180315_20180320_01_T1_MTL.txt
> sensor=oli8 date=2018-03-15 sun_elevation=45.06637424
> product_date=2018-03-20
> however go the error was:
> [image: image.png]
> appears not to be reading the data from PERMANENT?
> Thanks a lot
> Gabriel
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190616/e939027e/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190616/e939027e/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190616/e939027e/attachment-0003.png>
