[GRASS-user] sqrt sql
Frank David
frank.david at geophom.fr
Fri Mar 8 05:11:05 PST 2019
Thank you very much Vero !
Frank
Le 08/03/2019 à 11:10, Veronica Andreo a écrit :
> Hi
> functionalities like sqrt() or log() are not available in base SQLite,
> then you have to install an extension
> See v.db.update manual page and this wiki:
> https://grasswiki.osgeo.org/wiki/Build_SQLite_extension_on_Linux
> HTH,
> Vero
> El vie., 8 mar. 2019 05:22, Frank David <frank.david at geophom.fr
> <mailto:frank.david at geophom.fr>> escribió:
> Hello,
> How Is it possible to calculate a sqrt from attribut fields to fill
> another field, like :
> v.db.update map=myvector column=field2 query_column=sqrt(field1)
> Or is there any trick ?
> Thank you
> Frank
> grass-user mailing list
> grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/grass-user
-------------- section suivante --------------
Une pièce jointe HTML a été nettoyée...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190308/9db70c94/attachment.html>
