[GRASS-user] Anisotropy
Benjamin Ducke benducke at fastmail.fm
Sat Mar 16 14:39:52 PDT 2019
On 16/03/2019 21:24, Francois Chartier wrote:
> I thought Zscale was used to convert units ft to m, i didnt know it was
> for giving more weight to one direction.
That's only one application case. The manual page
goes on:
'Rescaling of z-coordinates (zscale) is also needed when the distances
in vertical direction are much smaller than the horizontal distances ..'
That is equivalent to what you are looking
for: instead of assuming that a process works
slower or faster in the Z direction (anisotropy),
you could also assume the speed is the same but
the Z distance is shorter/longer, no?
If I understand the manual page correctly, then
'zscale' only rescales Z values during
interpolation, but the original coordinates are
preserved in the voxel output.
Why not just experiment and check if it produces
a useful result?
Cheers,
Ben
> Le sam. 16 mars 2019 à 15:20, Benjamin Ducke <benducke at fastmail.fm
> <mailto:benducke at fastmail.fm>> a écrit :
>     On 16/03/2019 19:51, Francois Chartier wrote:
>     > Hi,
>     > Is it possible to add anisotropy when conducting interpolation for 3D
>     > raster.  I would like to give more weight horizontally than vertically
>     > in the 3D interpolation process.
>     'v.vol.rst' has an option 'zscale'.
>     Is that not what you are looking for?
>     Best,
>     Benjamin
>     > thanks,
>     > _______________________________________________
>     > grass-user mailing list
>     > grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
>     > https://lists.osgeo.org/mailman/listinfo/grass-user
>     Dr. Benjamin Ducke
>     Deutsches Archäologisches Institut (DAI)
>     Zentrale Berlin, IT-Referat
Dr. Benjamin Ducke
