[GRASS-user] Anisotropy
Francois Chartier
fra.chartier at gmail.com
Sun Mar 17 07:33:02 PDT 2019
thanks, i will try it in a little while and let u know. if i understand
the principal, then it assumes the point is just further in distance for
the interpolation but keeps the value at its original coordinate.
to give more weight to a horizontal direction, the z scale needs to be
increased vertically and potentially shortened horizonatlly.
On Sat, Mar 16, 2019, 17:47 Benjamin Ducke <benducke at fastmail.fm wrote:
> On 16/03/2019 21:24, Francois Chartier wrote:
> > I thought Zscale was used to convert units ft to m, i didnt know it was
> > for giving more weight to one direction.
> That's only one application case. The manual page
> goes on:
> 'Rescaling of z-coordinates (zscale) is also needed when the distances
> in vertical direction are much smaller than the horizontal distances ..'
> That is equivalent to what you are looking
> for: instead of assuming that a process works
> slower or faster in the Z direction (anisotropy),
> you could also assume the speed is the same but
> the Z distance is shorter/longer, no?
> If I understand the manual page correctly, then
> 'zscale' only rescales Z values during
> interpolation, but the original coordinates are
> preserved in the voxel output.
> Why not just experiment and check if it produces
> a useful result?
> Cheers,
> Ben
> > Le sam. 16 mars 2019 à 15:20, Benjamin Ducke <benducke at fastmail.fm
> > <mailto:benducke at fastmail.fm>> a écrit :
> > On 16/03/2019 19:51, Francois Chartier wrote:
> > > Hi,
> > > Is it possible to add anisotropy when conducting interpolation for
> 3D
> > > raster. I would like to give more weight horizontally than
> vertically
> > > in the 3D interpolation process.
> > 'v.vol.rst' has an option 'zscale'.
> > Is that not what you are looking for?
> > Best,
> > Benjamin
> > > thanks,
> > > _______________________________________________
> > > grass-user mailing list
> > > grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> > > https://lists.osgeo.org/mailman/listinfo/grass-user
> > Dr. Benjamin Ducke
> > Deutsches Archäologisches Institut (DAI)
> > Zentrale Berlin, IT-Referat
> Dr. Benjamin Ducke
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190317/e2e30cb7/attachment-0001.html>
