[GRASS-user] Grass GIS and McAfee
Francois Chartier
fra.chartier at gmail.com
Tue May 7 06:10:53 PDT 2019
use Avast, it will run a scan when u use a new module or when upgrading to
a newer version of grass, however after first scan it will run it.
On Tue., May 7, 2019, 01:25 Markus Neteler, <neteler at osgeo.org> wrote:
> Hi Ellen,
> DAmico, Ellen <DAmico.Ellen at epa.gov> schrieb am Mi., 17. Apr. 2019, 14:55:
>> Good Morning,
>> I am new to GRASS. I am using it in command line. I have discovered
>> that my McAfee virus checker is seeing some of the GRASS .bat files as
>> suspicious and obviously will not run them. In particular this file
>> (db.in.ogr.bat). McAfee doesn’t like the fact it has multiple “.” I was
>> wondering if anyone else has run into this issue and what their solution to
>> it was. I CANNOT disable McAfee. The agency I work for would frown upon
>> that.
> The only way I see is to contact their support. Maybe you have already
> done that?
> Best
> Markus
> Thank you.
>> Ellen
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190507/2242627f/attachment.html>
