[GRASS-user] Grass GIS and McAfee
DAmico, Ellen
DAmico.Ellen at epa.gov
Tue May 7 06:19:22 PDT 2019
Thanks for the suggestions. Unfortunately I do not have a choice in virus checkers, my work requires McAfee. I am working with McAfee on a resolution. They have been responsive but no solution yet.
From: Francois Chartier <fra.chartier at gmail.com>
Sent: Tuesday, May 07, 2019 9:11 AM
To: Markus Neteler <neteler at osgeo.org>
Cc: DAmico, Ellen <DAmico.Ellen at epa.gov>; GRASS user list <grass-user at lists.osgeo.org>
Subject: Re: [GRASS-user] Grass GIS and McAfee
use Avast, it will run a scan when u use a new module or when upgrading to a newer version of grass, however after first scan it will run it.
On Tue., May 7, 2019, 01:25 Markus Neteler, <neteler at osgeo.org<mailto:neteler at osgeo.org>> wrote:
Hi Ellen,
DAmico, Ellen <DAmico.Ellen at epa.gov<mailto:DAmico.Ellen at epa.gov>> schrieb am Mi., 17. Apr. 2019, 14:55:
Good Morning,
I am new to GRASS. I am using it in command line. I have discovered that my McAfee virus checker is seeing some of the GRASS .bat files as suspicious and obviously will not run them. In particular this file (db.in.ogr.bat). McAfee doesn’t like the fact it has multiple “.” I was wondering if anyone else has run into this issue and what their solution to it was. I CANNOT disable McAfee. The agency I work for would frown upon that.
The only way I see is to contact their support. Maybe you have already done that?
Best
Markus
Thank you.
Ellen
grass-user mailing list
grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190507/3e9c6825/attachment-0001.html>
