[GRASS-user] Grass GIS and McAfee
Francois Chartier
fra.chartier at gmail.com
Tue May 7 07:45:16 PDT 2019
mcafee would have to add executable for each module as not a virus in their
database.
On Tue., May 7, 2019, 09:19 DAmico, Ellen, <DAmico.Ellen at epa.gov> wrote:
> Thanks for the suggestions. Unfortunately I do not have a choice in virus
> checkers, my work requires McAfee. I am working with McAfee on a
> resolution. They have been responsive but no solution yet.
> *From:* Francois Chartier <fra.chartier at gmail.com>
> *Sent:* Tuesday, May 07, 2019 9:11 AM
> *To:* Markus Neteler <neteler at osgeo.org>
> *Cc:* DAmico, Ellen <DAmico.Ellen at epa.gov>; GRASS user list <
> grass-user at lists.osgeo.org>
> *Subject:* Re: [GRASS-user] Grass GIS and McAfee
> use Avast, it will run a scan when u use a new module or when upgrading
> to a newer version of grass, however after first scan it will run it.
> On Tue., May 7, 2019, 01:25 Markus Neteler, <neteler at osgeo.org> wrote:
> Hi Ellen,
> DAmico, Ellen <DAmico.Ellen at epa.gov> schrieb am Mi., 17. Apr. 2019, 14:55:
> Good Morning,
> I am new to GRASS. I am using it in command line. I have discovered that
> my McAfee virus checker is seeing some of the GRASS .bat files as
> suspicious and obviously will not run them. In particular this file
> (db.in.ogr.bat). McAfee doesn’t like the fact it has multiple “.” I was
> wondering if anyone else has run into this issue and what their solution to
> it was. I CANNOT disable McAfee. The agency I work for would frown upon
> that.
> The only way I see is to contact their support. Maybe you have already
> done that?
> Best
> Markus
> Thank you.
> Ellen
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190507/ab3fc38f/attachment.html>
