[GRASS-user] mapcalc combining raster and vector
Francois Chartier
fra.chartier at gmail.com
Thu May 9 04:59:17 PDT 2019
sure i will send that later. thks
On Thu., May 9, 2019, 04:00 Micha Silver, <tsvibar at gmail.com> wrote:
> On 08/05/2019 16:10, Moritz Lennert wrote:
> On 8/05/19 15:03, Francois Chartier wrote:
> Hi Micha,
> I have soil samples from boreholes where i have data points at every meter
> interval and where soil type changes. i would like to create a weighted
> average of soil property for lets say the first 1 m below the DEM, so that
> i can evaluate potential for infiltration across a watershed.
> You can use v.what.rast to read the DEM value into the attribute table of
> your points. Then you can do whatever calculations you need based on that.
> Moritz
> After Moritz's answer, It seems that your question is a data aggregation
> problem. If we can see the actual structure of your data (i.e. v.info -c
> or v.db.select then more specific responses might be possible. Best would
> be a small subset of the actual data.
> On Wed., May 8, 2019, 08:17 Moritz Lennert, <mlennert at club.worldonline.be
> <mailto:mlennert at club.worldonline.be> <mlennert at club.worldonline.be>>
> wrote:
> On 8/05/19 14:00, Micha Silver wrote:
> > You will most likely have to convert the points to raster. But
> before
> > that, can you explain what you mean by "located for 10 m from
> DEM", "10
> > to 20".
> Or, if you mean zones of equal height, you can transform them to
> vector
> polygons and use v.vect.stats on these polygons and the points.
> Moritz
> > On 08/05/2019 13:31, Francois Chartier wrote:
> >> Hi
> >> I would like to use mapcalc with types of input a DEM (raster)
> and xyz
> >> property (vector). basically, I would like to do a weighted
> average
> >> of data points located for 10 m from DEM, then 10 to 20 etc.
> >> _______________________________________________
> >> grass-user mailing list
> >> grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> <grass-user at lists.osgeo.org>
> >> https://lists.osgeo.org/mailman/listinfo/grass-user
> > Micha Silver
> > Ben Gurion Univ.
> > Sde Boker, Remote Sensing Lab
> > +972-523-665918
> Micha Silver
> Ben Gurion Univ.
> cell: +972-523-665918
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190509/3e827871/attachment-0001.html>
