[GRASS-user] mapcalc combining raster and vector
Francois Chartier
fra.chartier at gmail.com
Thu May 9 19:25:57 PDT 2019
| Database: C:\Users\hello\Documents\grassdata
| Title:
| Map scale: 1:1
| Name of creator: hello
| Organization:
| Source date: Thu May 09 19:17:57 2019
| Timestamp (first layer): none
| Map format: native
| Type of map: vector (level: 2)
| Number of points: 316866 Number of centroids: 0
| Number of lines: 0 Number of boundaries: 0
| Number of areas: 0 Number of islands: 0
| Number of faces: 0 Number of kernels: 0
| Number of volumes: 0 Number of holes: 0
| Map is 3D: Yes
| Number of dblinks: 1
| Projection: UTM (zone 17)
| N: 4891804 S: 4789063
| E: 701767 W: 578337
| B: -272.2963 T: 472.80127
| Digitization threshold: 0
| Comment:
(Thu May 09 19:22:41 2019) Command finished (0 sec)
V.DB.SELECT
cat,int_1,int_2,dbl_1,dbl_2,dbl_3,str_1,dbl_4,dbl_5,dbl_6,str_2,dbl_7
1,11105041,17,580165.3,4873100,279.89767,SAND,277.7976701,279.59767,1.21,WWR,5e-006
2,11105041,17,580165.3,4873100,279.89767,SAND,275.5976698,277.7976701,1.21,WWR,5e-006
3,11105041,17,580165.3,4873100,279.89767,SAND,269.1976702,275.5976698,1.21,WWR,5e-006
4,11105041,17,580165.3,4873100,279.89767,SAND,277.7976701,278,1.21,WWR,5e-006
5,11105041,17,580165.3,4873100,279.89767,SAND,277.7976701,279,1.21,WWR,5e-006
6,11105041,17,580165.3,4873100,279.89767,SAND,275.5976698,276,1.21,WWR,5e-006
7,11105041,17,580165.3,4873100,279.89767,SAND,275.5976698,277,1.21,WWR,5e-006
Le jeu. 9 mai 2019 à 04:59, Francois Chartier <fra.chartier at gmail.com> a
écrit :
> sure i will send that later. thks
> On Thu., May 9, 2019, 04:00 Micha Silver, <tsvibar at gmail.com> wrote:
>> On 08/05/2019 16:10, Moritz Lennert wrote:
>> On 8/05/19 15:03, Francois Chartier wrote:
>> Hi Micha,
>> I have soil samples from boreholes where i have data points at every
>> meter interval and where soil type changes. i would like to create a
>> weighted average of soil property for lets say the first 1 m below the DEM,
>> so that i can evaluate potential for infiltration across a watershed.
>> You can use v.what.rast to read the DEM value into the attribute table of
>> your points. Then you can do whatever calculations you need based on that.
>> Moritz
>> After Moritz's answer, It seems that your question is a data aggregation
>> problem. If we can see the actual structure of your data (i.e. v.info -c
>> or v.db.select then more specific responses might be possible. Best
>> would be a small subset of the actual data.
>> On Wed., May 8, 2019, 08:17 Moritz Lennert, <mlennert at club.worldonline.be
>> <mailto:mlennert at club.worldonline.be> <mlennert at club.worldonline.be>>
>> wrote:
>> On 8/05/19 14:00, Micha Silver wrote:
>> > You will most likely have to convert the points to raster. But
>> before
>> > that, can you explain what you mean by "located for 10 m from
>> DEM", "10
>> > to 20".
>> Or, if you mean zones of equal height, you can transform them to
>> vector
>> polygons and use v.vect.stats on these polygons and the points.
>> Moritz
>> > On 08/05/2019 13:31, Francois Chartier wrote:
>> >> Hi
>> >> I would like to use mapcalc with types of input a DEM (raster)
>> and xyz
>> >> property (vector). basically, I would like to do a weighted
>> average
>> >> of data points located for 10 m from DEM, then 10 to 20 etc.
>> >> _______________________________________________
>> >> grass-user mailing list
>> >> grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
>> <grass-user at lists.osgeo.org>
>> >> https://lists.osgeo.org/mailman/listinfo/grass-user
>> > Micha Silver
>> > Ben Gurion Univ.
>> > Sde Boker, Remote Sensing Lab
>> > +972-523-665918
>> Micha Silver
>> Ben Gurion Univ.
>> cell: +972-523-665918
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20190509/f18d14f9/attachment.html>
